@ GTS4WD: I second that, id take the auto, but no swaps lol, im over the new P's laws already,makes people selling turbo cars so much harder.
LOL... aye... but then selling non-turbo cars ain't easy either... P-platers are becoming wussy and not willing to fork out to buy these awesome cars... Where have the car nuts gone? Where are the Jeremy Clarksons, who would mortgage their homes for a car (if he wasn't married with 3 kids)?
hey mate would u be interested in swaping for a 99 vt commodore, 144000km's, very good condition, cd player, tow ball, white, auto rego till november. does urs have rego?
Not really... Sorry. Thanks for offer though.
BUMP
parts coming in from Japan....
a) White bonnet lid
b) Pair of white wing mirrors
c) Pair of white wing mirror add-ons, which have yellow indicator LED strips over them... look at picture...
these will be provided for an extra $400.... the LED wing mirror add-on is worth that much alone...
Picture of part ©
Also have a wood-trim kit for car... not installing in case new owner doesn't like the effect.... but can be provided for extra $50 (ebay sells it for $180 incl postage and RRP is $400).
Edited by somos
  • 4 weeks later...
  • 4 weeks later...
Item: Nissan Skyline R33 GTS Sedan from 1994
Website: Trading Post ad
Item Condition: Excellent
Reason for Selling: Want Toyota Cressida or Vl Calais (may consider others, so pm or reply here), also can't afford insurance ($1600 for $3500 of excess...:ermm: ), so NO IMPORTS.... sorry... maybe next year.
View this as a MUCH better alternative to your Camrys, Commodores (the base model ones), Falcons (same thing again), Accords, etc... Its a fast and nimble, yet comfortable and practical 4-door family sedan. With technology that's durable and not found in new family cars today.
Price and Payment Conditions: NOT $8,888 NOT $8378 BUT
$7500 ono with FREE Road Angel GPS, with latest Sirf Star III chip.
Want this car gone, have another one in mind....
Extra Info: Price is Negotiable.
BAD POINTS:
Car has got re-tread tyres, good time to think about getting rims.
One tyre's retread is ripped.
Small 5-cent rust spot at bottom of rear windscreen.
2 vinyl tears in door trim (can be repaired using stuff from SuperCheap Auto).
Scratches around plastic trim for electric window switches.
Right parker light is out, needs bulb replaced.
Remote key needs contact for battery re-soldered.
Wing mirrors are different colour. due to previous owner having no time to respray after wing mirror clipped car park pillar.
GOOD POINTS:
Engine superbly maintained by previous owner (only have had car for 1 month, selling due to ridiculous insurance quotes).
Has HICAS 4-wheel drive system, which was on R32 GTR.
Has 5 speed automatic gearbox, which is NOT found on turbo versions of this car. Very smooth gear changes, 1 gear makes a huge diff for the automatic gearbox.
Sedan, so you can use as family car.
Have put blue LED lights for dashboard.... looks really cool.
Have JL front splits installed, rear speakers are unknown 6" (came with car).
Have Alpine headunit, can control iPod from headunit (don't have the cable though).
Been running BP Ultimate for the few months through car.... very smooth running now.
Have repainted exterior plastic door trims, so now in deep black.
4 NEW tyres
MORE PICTURES ON PAGE 2
Pictures: 2132380836_9e0a0c308f_o.jpg
Contact Details: Pm here. Or contact me at 0431408578
Car has had major service done recently. Changed the cambelt (aftermarket), bearings, power steering fluid (Castrol), brake fluid (Super DOT Castrol), brake pads (QFM) changed & engine oil (Castrol Magnatec). Car stops on the mark better, steering is lighter and more responsive and engine is more responsive.... would recommend also doing a A/T fluid change to get the best results (apprx. $200 already bought A/T fluid)
This is a rare Series 1 R33 sedan, don't buy a coupe which you're going to have to sell when you have a family. This is a car you can live with everyday and brings a smile to your face.
Selling because i want a change... looking for a subaru liberty GX 91-94 in manual... with the hill clutch control feature.
Test drive car ANYTIME sleep at 2am... only for viewing after the 13th of May 2008. Car located in Epping, NSW (Sydney).
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
