Ok heres the deal, ive got an RB25 with a mapped RB20 ecu running the show, VCT is not operational and it has never really fazed me since with the decent tune on there its got loads more down low then the old rb20 anyway. I have since added a GCG supplied GT3071R with internal gate, it has the GCG cast .71 AR rear housing (a copy of the OP6 housing if you will)
On boost, the car is an animal! goes pretty damn hard, makes 265 rwkw on 16 psi and 283 rwkw on 20 psi, since its a stock internal motor i keep the boost to 16, and i find its more then enough power anyway, BTW its a drift car.
Heres my issue, i do find that down low suffers a little, its a little laggy and i dont believe its the turbo's fault but more or less a fault of not running VCT.
I was thinking of adding some Jun spec 254 cams with 8.9mm lift. to improve the low to mid power range which is what im after, as peak power is plenty atm.
Thoughts?
Sounds like a good idea. As your not running the VCT, you could either, buy two exhaust cams, or make an adjustable camwheel out of the VCT camwheel(by elongating the bolt holes that secure the outer to the inner) I would try modifying and playing with the cam timing first, maybe just a cam on the intake, dialled in on the dyno would be all thats necessary
Rezzpect man :(
keep stock cams
get VCT working with an aftermarket cam controller if you have to
tune the crap out of the low load ign timing - 7x7 should do it on the IGN map - go as far as 50deg in some spots with 100ron and youll love it
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
