can any one tell me whats the best hks spark plug made for neo6 engine :( .i need to get some for my car.but there
is so many diffrent f**king numbers and models... so where can i get them from ? any one sale them in the country?
cheers guys..
https://www.sau.com.au/forums/topic/202142-spark-plugs-what-to-get/
