K, Original problem was a intermitant missfire. Was told by everyone "yerrrp ya coil pack".
Chucked in brand new Splitfire Coilpacks and NGK PFR6G-11 Plugs.
Its now running like a complete slug and 10 times worse. Jumpy, missfire, shootin black smoke. WTF?|
Help ne one.
https://www.sau.com.au/forums/topic/202143-pissed-off/
easy, chances are the coil packs are playing up. So clean them up, silicon them up, and gaop those plugs down to 0.8mm and youi should have no drama;s
+1 Agreed, your coil packs and plugs need changing. Doesn matter to wot.. just change. :D:)
Thats sux Zelda, but mod;n aint easy (otherwise there'd be no mechanics) Sure what ur experiancing is a ignition health related misfire? Not timing (bad ECu sensor inputs) or simply fuel pressure etc?
PS: a thread named "pissed off" implying suggestions you got from SAU members screwed you over... isn't the best way to get help. Theres a vast demographic here, what you take away and use to help you spend your coin (VS taking to mechanic) is up to you :(
Edited by GeeTR
https://www.sau.com.au/forums/topic/202143-pissed-off/#findComment-3590511
I would surgest you put the platinum or iridium spark plugs aside just for a while. Give it new ordinary copper spark plugs gapped at 0.7 or 0.8mm. You may find this fixes the misfire for a short time at least.
Your black smoke means its running rich. Could be many reasons for that, but it needs to be fixed.
What happens is the rich mixture fowels up the plugs very quick, and fancy plugs do not like that. Then you get a misfire. With a modifyed turbo car, you just have to keep giving it new copper spark plugs every few months unless you get it tuned well enough not to do that.
https://www.sau.com.au/forums/topic/202143-pissed-off/#findComment-3590572
haha sorry wasnt intending on aiming the pissed off bit toward fellow SAU members was more so jus pissed off in general at the time. gonna have another stab at the car today and suss regapin the plugs down to 0.8mm.
https://www.sau.com.au/forums/topic/202143-pissed-off/#findComment-3590736
MY 34 Began misfiring when I installed new plugs, perhaps because the mech played with the coils I dont know.. On idle and light accleration or just on throttle it miss fires like a bitch.. A tune fixed that up alot perhaps that may help.
Id say from the results I got from a slight tune it may be tune dependent. However a 1.1mm gap is massive regap the plugs to 0.8 if your going to pump more boost through it.
Strange it would be blowing black smoke, as in not burning fuel correctly? Are all the sparks and coils firing?
https://www.sau.com.au/forums/topic/202143-pissed-off/#findComment-3590766
WTF my R33 s2 was the same, it wouldn’t idle and would miss and splutter at 10PSi
I got some Spitfire Coil packs and some iridium sparkplugs @ 1.1mm and have never looked back.
Low end response was improved and now loves to rev to 7000rmp all day
even at 1 bar stock turbo not a prob (not run 1 bar on street cos stress the stock turbo too much)
hope this helps!
PS Series 1 or 2?
https://www.sau.com.au/forums/topic/202143-pissed-off/#findComment-3599230
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
