Item: HPI Nitro RS42 remote control R34
Age: A few years old but only ran maybe 10 times.
Condition: Virtualy Brand New
Price: $450 (i paid just over $1000 at the time)
Contact: 03 5335 9168 or 0449611791
Comments: This thing flys, not literaly but it goes about 70km/h and there is a long list of performance upgrade parts that can be
brought like racing exausts, cylinder heads, brakes, transmissions etc ..
https://www.sau.com.au/forums/topic/202157-hpi-nirto-powered-r34/
Yes i have pictures but when i tried to upload them it wouldnt work, if you give me your email address i will email em to ya, i will also try and upload em again here ..
Its 1.10th scale, which is pretty big. It comes with everything needed, glow plug cattle prod & charger, a little fuel, fuel squeeze bottle, remote & servos ..
FILO34 - Could you please upload the pics i emailed you of the car in this forum for me cos when i try to it just hangs ..
I may need to try a different web browser, im using netscape .. anyone else with netscape have this problem ?
  • 1 month later...
