Hey all,
I've had a really weird problem just happen to me.
My indicators in my car will not work when I go to indicate... My hazards work when i turn them on (All 4 at once), but when i got to turn a corner and indicate for instance, no sir, NOTHING happens at all. No noise, no lights, nothing !
I have had a look at my lights, they are fine and all work. I'm hoping its just a resistor or something like that, but I have no idea which one it would be or how to fix it, as all the writing is in Japanese !
If any of you could give me any help at all, it would be greatly appreciated !
p.s I did do a forum search and nothing came up..
Thanks.
R32 btw
Edited by drifitz
https://www.sau.com.au/forums/topic/202199-weird-problem/
Had the same problem when I had my R33.
I had aftermarket front Indicators..and had to fiddle around with the wires that went into it, check the wires out and it should work
but check fuses, will take alot of time because there all in jap..but worth it..haha
first thing I thought was it was the stick that was fcuked..ended up just being some wires.
hopefully this helps some how...
https://www.sau.com.au/forums/topic/202199-weird-problem/#findComment-3591178
yea either the indicator stalk or mabe the flasher unit (real name?) thingy you know the one that makes the noise when your indicating
i had one go on my work ute and no lights noise etc hazards still worked cause they were on a different flasher unit thingy
hope this helps
https://www.sau.com.au/forums/topic/202199-weird-problem/#findComment-3592060
Could be the relay, Nissan decided with the R32 they would run the relay for the stalk through the hazzards
Would that affect my hazards? My hazards do work though... so im guessing its probably the stalk..
Would anyone know if getting the stalk fixed is a big job / expensive?
https://www.sau.com.au/forums/topic/202199-weird-problem/#findComment-3592528
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
