This is our 99Z subwoofer, as used by Alan Dante, the loudest man ever, 180.5dB.
It's not cheap (at around $5000), but it is the very best you can get.
Our course, we have "normal" speakers as well, even our entry level 512 ($249) is hand made in the USA in the same factory, by the same people, with the same glues and materials as used in the 99Z.
All DD gear is designed for sonic excellence. A lot of people make the mistake of thinking that it's "SPL only", this is definitely not the case. We win in SPL because of efficiency, power handling and being over engineered.
A single DD woofer can outperform 3-4 "normal" woofers. A lot of people use our 1508 8" woofer as it kills most other 12s. This saves weight and money.
Phil
Edited by DD Phil
Apologies for that - I've never heard of Digital Designs before in my life, also I'm going to sue Pioneer for false advertising on their site, stating they've won the main world wide SPL comp many a year in a row. However I still don't see how a 12" sub pushing a max of 1000watts is anywhere near the class of a 15" pushing 15,000 peak and 7,000 continuous... with 4inches of excursion. Sorry I just don't see it happening. Referring to the "Rainbow" subwoofers now. Also, to FIGJAM who stated that as far as he's concerned, Pioneer's range only deal with high frequencies.... refer to http://www.pioneer.com.au/products/car_ent...ange/index.html
I guess we'd need to know whether this guy wants to spend a lot of money or not, whether he's looking for SPL or dB performance, and whether he's after gut wrenching bass or something to make his hip hop and rap sound like pop candy tunes. Personally I'd prefer low hard hitting bass with plenty of excursion and QUALITY, rather than just raw volume. I haven't even checked out the DD range or anything, but from the information Phil gave up there, it gives me the impression that they can handle much more power than what they're rated at. Anyway, wasn't trying to pick a fight simply help the guy. Honestly though, I'm going after Pioneer for 10million.
If u have never heard of a brand u dont need to get nasty mate. Rainbow is a German made product, very high quality, based around Sound Quality products. They also held the title for having the best set of component speakers for 5 years in a row which was the world standard everyone was trying to reach, these are called RAINBOW REFERENCE and also worth more than a small deposit on a house.
You speak of Earthquake and Pioneer, but u dont realise u are comparing them to Digital Designs MADE IN THE USA, and RAINBOW MADE IN GERMANY.
I would appreciate u learn a few things about car audio before getting nasty and exploding at people and get out of your small minded ways of thinking and open yourself to exploring other possibilities.
We as an Australian market are only exposed to department store brands IE PIONEER, which means just because u know it doesnt make it brilliant. It does what its meant to do but its nothing special.
hey all
my 2c, depending on budget, buy something that is adequate for your needs. you dont need to pull 180db to have a good system. that is just an INSANELY LOUD system lol honestly kicker are good and arent overly priced. on the same par you can get JL gear. in regards to subs you should lean towards Digital Designs (DD). i work in JB and have my favs but honesltly some of the cheaper stuff doesnt sound too bad either. a pair of JVC 6x9's going for $109rrp goes pretty damn good for that price. for speakers i'd go with JL VR's (or ZR's if you dont mind spending a little extra) or the kicker's. 90wrms for component speakers are very loud. as for the amps id go 5channel kicker which isnt too bad coz its like having 2amps in one. 4x60 (i think) and 1x420rms (pretty good for a 5ch amp) otherwise JL 4x75 as Bonsai mentioned for the speakers and a WARHORSE kicker would be good for a few thousand rms lol
honestly build a system that will make you happy and fits the budget!
myself im using a pheonix gold sub wth a coustic amp, crap sony deck (soon to be updated) infinity 6x9s and kicker splits (very loud yet clear :whistling: )
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
