Gday all,
I am having a bit of a problem with my car.
About 6 weeks ago I put a new battery in the car cos the original one from japan died. I had been driving around for a few weeks and everything was fine. Over the last week I have noticed the electrics in the car getting weaker, windows winding up slower, stereo cutting out etc...
This morning i got out my multimeter to check the voltage on the battery and found that the voltage was the same whether the car was running or not. I then removed one of the terminals too see if the car would stall and confirm that there was a problem with the alternator. When I removed the terminals the idle speed of the car picked to where it would normally be and when taking a measurement from the leads, the voltage had returned to where it should be and increased/decreased with revs as per normal.
I then turned my attention to the battery. I put my battery into my parents car and started it, I checked the voltage of the battery and everything was working as it should, my battery is fine.
I then put my parents battery into my car to see if there was any difference. No difference, voltage was still the same whether the car was running or not.
Does this mean that my alternator is on its way out, only putting out just enough power to keep my car running, or could it be something else?
Edited by ShanO`
https://www.sau.com.au/forums/topic/202207-electrical-problem/
yeah your alternator is dead in some way. when it is charging it will give over 13v, if you only get 12 you are running on battery power. start the car and disconnect the battery, see if it stalls (not enough voltage to run coils and computer)
easiest fix is to remove alternator and exchange it, a good auto electrical place should be able to find somehting that fits (rb30/vl commodore should work)
Does your car 'squeak' on start up in morning? might be loose belt on alternator pulley (which is either re-tension or replace)
I don't find it a coincidence that one battery died and the other one is 'under stress'.
Yup, sounds like ur alternator is on its way out...
Mine died few mths back on the 34...don't ignore the symptoms like I did...car completely shut down one day...lucky it wasn't on a busy street...
Get it replaced or reco-ed by an auto elec quick smart!
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
