Hey guys just looking at upgrading to GT RS on my rb26 and i am woudering if anyone has them fitted (or ss)so i can come for a ride to feel the lag/power they are making.
Cheers guys.
Would prefer in an R32 gtr as thats what i am comparing it to.
https://www.sau.com.au/forums/topic/202220-anyone-running-gt-rs-or-ss-in-a-gtr/
Wow big difference between the RS and the SS. From everything I've been reading, unless you have increased capacity don't go the RS. I asked a similar question when I was tossing up the 2860R-5 (also known as GTSS) to the HKS GTSS and got no response. I ended up with the 2860R's
Every car is slightly different but I can take you for a spin.
That would be great man, i have hks 25/30's ATM and they arnt to bad. The RS are ment to spool at the same point as the older 25/30s due to its newer bearings or somthing. But thats just what i have heard, and if its true i will be useing the GT RS.
However i suspect that the RS's are more laggy its just how much.
Cheers John.
Edit: We should go paintballing again. That was Fun. :D
Edited by BNR32t
Cheers John.
I have a direct comparison graph between RS's and HKS 2530's...nothing else changed...will scan and post.
This is only a turbo change but not direct comparison as i now remember they were at different boost levels with different fuels used but you can see that with NOTHING CHANGED they are laggier.
Now the engine was designed and built with HKS 2530's in mind, so the GT-RS's were not able to stretch their legs or come on harder earlier...a GT-RS engine has to be done completely different (you build an engine similar to that if you were running a big single..massive cams porting etc)
also anyone who says they need a larger capacity to be fully effective is just guessing, and not speaking from experience.
My advice...if you have plenty of $$ go the RS route and build a proper engine to suit, they are an awesome set-up on a big $$ GTR engine...or...if its a basic engined street car, go the SS's
I don't think anyone was saying exactly that, what they were saying is that they are laggy without an increase in capacity and your graphs, particularly the first one shows it. On a rb26 motor not specially designed for them they are a lot laggier. Once you build a motor specifically for any add on's they obviously run better.
Not that different dyno runs tell the full story, thats why Keith wanted to test in real life the difference.
both engines are RB26 mate...identical capacity...but 1st one had small cams and little to no head work...not a good match for the turbines...with correct cams and head work you can get these to be just as responsive as 2530's...as now the power comes on almost 1000rpm earlier...and makes power all the way past 9500rpm. Also has a big flat fat 5000rpm max torque curve...did you notice how peaky the 2530's torque curve was?
What im trying to point out is if you only change the turbo's then YES they will be laggier...but if you know what your doing and are going to build an engine to suit them then they can be awesome and responsive...WITHOUT an increase in capacity.
Now we get to the crux, thanks for the input and experience DiRTgarage
I think we are saying mostly the same thing here, but maybe a difference on what acceptable lag is.
1. The GTRS are slower to spool up than the 2530's (you just said that above)
2. The 2530's are slower to spool up than the GTSS (see rb26 forced induction thread)
3. Changing/modifying the head and particularly cams can lower the RPM where the turbo's become effective
The original question of the op is the difference between the GTRS and the GTSS, a huge difference you have to agree. With cams or an increase in capacity the turbo's can spool up sooner, what ever turbo's they are. GTRS for maximum power, drag racing and lagier. GTSS for everyday driving and track work, more response.
From my perspective, I do not consider with all that head work etc and the turbo's coming on full at 5000rpm to be acceptable, I would be looking for 3500 to 4000rpm. With no work done to my engine the turbo's come on strong at lower RPM and with lower PSI. If I could lower my RPM where the turbo's come on that would make me much happier. Cams can only go so far, increasing capacity seems to be the next logical step.
I never say I know a lot but I do read, so has this forum led me to the wrong conclusions above? Everything being the same, would increasing capacity lower the point that the turbo's make power?
I have HKS GT2530's and dumps on my 26 at the moment.
Engine mechanically stock except 260 poncams and cam gears not dialled in, plus all the usual support stuff.
I get around 17psi at 5000rpm, and I think thats 1000 rpm too late, comnpared to R33N1's anyway.
I'd be checking out where your torque band would be too with GTRS compared to GTSS. With 2530's I've lost a fair bit of torque in the 3500 to 5500 range. I've had no real indication of what I should dial cams in to.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
