Have you run it at the Hillclimb before? I don't remember seeing you out there, if you have, apologies if I didn't recognise you... when did you run out there last?
Never driven it :thumbsup:.
The Old man has been trying to get me into it for the last year. Its just i work weekends.
And the car has never run at the ACT hill climb track.
Well you won't have to worry about being the only open wheeler, there is a few that get around out there. They do pretty well too, have a look at the SDMA website for results to get an idea of their times.
Nice, is the GTR retired to show status? Finally no more people asking what you are doing with it on the track lol.
Yes, supposedly... its not going to be easy cos I will miss her on the track. Maybe now and then wont hurt :P
wow... certainly a hobby and a half! just wondering if u know the output of the v6? why they chose that specific engine during manufacture?
cheers and the best of luck with racing it in the future
That is awesome Michele, have you driven it around your neighbourhood? :O:D
I've started it a few times and cringed at what the neighbours might have been thinking. I haven't driven it anywhere yet :) gotta get to Wakie sooooooooooooon, its killing me.
I don't know the output, but they tell me I will know as soon as I install the AIM Data Dash, they say its better than a Dyno for getting those sorts of results.
height adjustable suspension? for the speed bumps at woolies i mean. and where exactly do you put your shopping? i'd laugh if you did take it to woolies and got pulled over by that copper from summernats. priceless.
i like the pic taken from way above...
'this is what you will see if you parachute onto Michelle's car...'
you must be seriously wound up with anticipation...
Edited by Scooby
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
