  • Replies 65
always prefer high reving N/A power plants. less headache in general and a linear power delivery.. great general driving, be good on fuel down low driving in low rpm torque and still have the poke up top.
why do people call this car hybrid ? whats hybrid about it ?
wow good point about the vspec, i wonder if it could crack into the 2's for 0-100 :rolleyes: considering that the time of 3.3 was recorded by edmunds on a dirty surface that they claim did not have alot of traction.
Hmmmm I'm really looking forward to seeing the v spec, mostly just to satisfy my curiosity given the many reports I have read.
One or two reports have stated that the vspec will be no more powerful. In my opinion they need to increase the power or reduce weight big time. from what I have seen the gtr can only just keep with the 911 turbo in a straight line and therefore it making gains everywhere else. increasing power will just top it off. i'm sure power could be increased relatively easily by using a similar approach as porsche has taken with the 911 turbo's turbos. the gtr's turbos are relatively simple and cheap by comparison. but what would i know really.
another report indicated that they may have driven the v spec when everyone else was testing the normal gtr. the reason for this relates to the fact that they were taken to a different area to all other journos. the car had a roll cage in it. the journo stated that it didn't feel any faster in a straight line. they indicated that it was much looser and the engineers were very interested in hearing their view on the drive.
No hybrid. Toyota market their higher end luxury cars as a Lexus. Being that its called a LEXUS LFA but is said to be the next TOYOTA supra, someones got their wires crossed and decided that its now a hybrid. And now runs on a half petrol/half electric powerplant :-)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
