hey guys, well story goes rb25det.... no power under 2500rpm and then creates boost but has no pull so i checked compression.
pulled all 6 plugs out held car under wot and tested results as follow
p1. 90 psi
p2. 90 psi
p3. 85 psi
p4. 80 psi
p5. 90 psi
p6. 95 psi
pulled timing cover off as thought belt may have jumped. timing is all good pulled tapet covers off to see if cam turns yes both do...
is it possible to be low on all 6 cylinders car starts and idles smooth!!!
help please?
https://www.sau.com.au/forums/topic/202257-oh-hell-no/
no the cam cannot be, however other issues could be worn keyway in the crank, causing the crank to rotate a few degrees out of timing, ive seen this one a few times now.
was the comp test done with the motor warm, all plugs ut and throttle held at WOT while cranking?
https://www.sau.com.au/forums/topic/202257-oh-hell-no/#findComment-3591952
YES the cam gear can move on the cam, if the dowl locator snapps on the cam then what happens is that the gears are still in time but the cam is retarded, this happened to my engine and it had 30psi in all cyls and it still ran as well.
Take the harmonic balancer off, take the timing covers off and put the engine on TDC and make sure the bottom timing mark is correct as well as the top ones.
Get a shifter and put on the cam (you need to take the cam covers off) and try turn the cam gently. If the cam turns without the cam gear turning then you would have snapped the dowl and it might only be a little bit out. It can get worse and if you dont fix it now it could slip around and smash valves.
Also check your compression tester, the engine could be all OK
https://www.sau.com.au/forums/topic/202257-oh-hell-no/#findComment-3593817
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
