Can any one help? There was a pair of 210 hot plates on ebay a couple of weeks ago that sold for around $750... did anyone on here buy them?
Some guy just bumped into the back of my bro's car & they managed to crack one of the lenses. Of course the guy was driving a crap box, with no insurance, & 'doesn't speeka da englase'. :)
If someone on here bought them, or knows who did, I might need to get a copy of the invoice or something to show how much they are worth.
I know there is a set for a late/211 on ebay now for $350, but they are a different shape to what he's got. He paid alot more than that for his too, but has recently moved house, and can't find the invoice papers for them anywhere.
So, yeah, if the guy turns out to be a pain & doesn't want to cough up the cash, an invoice might help.
cheers.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/
Hey mate,
They $770 set went to a guy named Ralf in Germany, who is doing an amazing restoration on a red C210. Oddly, no-one bid on an identical set listed for $550. There are more sets readily available on Yahoo auctions Japan, some going quite cheaply, although you will have to ask around politely in the Japan forum to find someone in Japan willing to bid and post on your behalf. NO-ONE ships internationally from Yahoo Japan. Grr.
Which lense got broken? I have some semi-smashed up hotplates and may be able to salvage the lense you need anyway.
Cheers,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3595348
Hey mate,
Cheers,
D
Yeah, I've never really been involved with yahoo jp anyway...
If you've got bit n pieces, that would be tops! Its the left hand tail light, the red ring lense on the numberplate side.
Not sure if they come apart of fit from side to side or whatever, so not too keen to bid on the 211 ones on ebay atm either.
So yeah, if you can help out with a lense my bro would be stoked.
Cheers,
Michael.
p.s. those jap mirrors & gt's I got off ya look trick on the car too
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3596876
Great news about the mirrors and badges and I'm more than happy to help with the lense. I'll try pulling the smashed one apart on the weekend. No promises though, all the wrong bits may be busted!
Ill get back to you shortly,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3597562
Those JDM lights on ebay are $250 down from $350. That's getting a little more realistic now - especially seeing the chrome trim around the outer edge of the plastic hasn't dissolved into a brown ring of rust yet... Like mine. Shame they don't come with the centre garnish though.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3599012
Does this look right? How does $35 sound?
Cheers
sorry about the late reply, work..sleep..work..sleep..
Does that centre reflector part come out? My bro's has a reverse light white/clear centre(which isn't broken)
cheers,
Michael.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3621110
hey hey,
I had a play with it and although there is a (seemingly useless) screw that I removed the centre part doesn't seem to budge. I didn't want to push to hard on it though as I'm kind of prone to breaking stuff. I don't see how it can be removed easily though. Maybe it's glued in place. The lights that this lense is from has the reverse light as a separate rectangular lense.
Cheers,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3621276
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
