i have a 3540 with the smallest exhaust housing on a 25det and a stretched rev limiter to 7,500 and it wakes up late 3,000's but pulls very very hard to the limiter.
so on a rb20 it will be alot of more laggy
i would go a 3071R or a 3076R .63 for rb20
Yeh, no doubt woudl be laggy. But if ppl put them on big power SR20s then i see no reason why not an RB20. Only you would want it to be a dyno car or a drag car, not a daily streeter.
If you are running 81mm pistons for a bump in displacement, with around 9.0:1 compression. Dont go too big on cam duration, say 256 and 8.8mm lift. Stick with std inlet manifold and make sure the 3540 is running a nice exhaust manifold and is well tuned with cam gears used to dial it all in.
I see no reason why the thing wont be on song in the mid 5,000rpm range. Wil be able to rev the thing to 8,800rpm and make a good wack of power, around 320-340rwkws (depending on the turbo spec)
Worst case throw a shorter diff ratio in the thing.
Whether it makes sense to do all this to an RB20 instead of a bigger brother its hard to know and not for us to say. But if you want a more streetable setup with i would think a 3076 woudl definitely give you a better compromise of power nad drivability.
Have you looked at the Turbonetics or ITS range ?
yeah i was assuming that it would be more laggy because of a smaller displacement engine with more pistons, so a shorter stroke? but sr20s are the same displacement with less pistons so bigger bore x stroke?
if its a streeter no way i would put that on a sr20 without MASSIVE cams and a 9,000rpm limiter, just too big of a turbo for down low power.
pffff dont listen to the RB20 haters. im putting a GT3040 on my RB20, will be slightly less laggy.
if you want response obviously its far to big, but with a full build it will be alot of fun.
two words.
do it......
there was a r32 in a recent zoom issue with a built rb20/gt3540
specs below, that motor has since expired but meh.....
To cut the list short -
Forged internals
Standard cams
Tomei cam gears (in anticipation for cams.....)
GT3540 turbo (high mount)
Turbosmart 38mm ext. wastegate (with screamer, love that sound!!)
110mm thick front mount
3 inch dump into 4 inch exhaust
Nismo 555cc injectors
Bosch 500hp fuel pump
Link ECU (upgrading to Microtech LT-12 this week)
Turbosmart E-Boost2
Alloy triple-flow radiator
Car made 293rwkw/393rwhp @ 21psi (more to come). Would post up the dyno sheet but I don't have a scanner!
Is also featured in current issue of ZOOM (# 118)
http://www.skylinesaustralia.com/forums/Rb...html&st=140
^^ RB20 power thread is the best place to look. theres another two GT30 series powered RB20's on the page after the above one.
Edited by esky_mad
QUOTE(LTHLRB @ 20 Jan 2008, 02:31 PM)
same here. i have a .82 rear housing. and boost comes on at about 3200-3500.. a greddy plenum helps.
if u are after PEAK power go for it mate. but it will only last for 2000rpm..
if your after response AND decent power go a 3071R
yeah mine comes on at around that aswell.. last time i drove it i stopped looking at the tacho and concerntrated on keeping it straight it shot up very fast fron around the 3000's thats full boost, not starting, but already at 18psi
respect to the almighty gt3540....
if u want a kick in the pants and would be happy with a constant whiplash injury go the 3540... but as i said before on a rb20....it will only last for 3sec :)
it just wouldnt do it, u or the car any justice
Edited by r33cruiser
two words.
do it......
Forged internals
Standard cams
Turbosmart E-Boost2
Yes but if you read the article closely it doesnt even start to see positive pressure untill 4600rpm
Buy that time even old dak daks will have hosed you off the road.
think of it this way......nothing nothing nothing......boost...wheel spin....rev limit, change gear and repeat....
GT3076 at the most for a street car.
But its your car so do what u like. :blink:
boo to the RB20 haters.
with the right cams you can dial in more than respectable response for the loyal old beast.
remember people that youre comparing other motors to the RB20, which is kinda dumb considering there in a completely different league.
i say go for it mate. then if you dont like it change the turbo.
But its your car so do what u like. :D
in my opinion i couldnt care less if a dodgy old non turb r33 beat me, cause i know id be having a hell of a lot more fun. isnt that what modifying your car is all about.
that last comment always annoys me :blink:
my 2c.
two words.
do it......
Forged internals
Standard cams
Turbosmart E-Boost2
meh you could do that with a TD06 and far less lag.... 293rwkw is nothing special...
your a bloody idiot esky mad.
such noobieness.
just go a 3071R or a 3076R .63 for rb20
ONLY if u like driving around on vacuum would u ever go a 3540
i agree with uras on this one, the td06 is underated. on a built engine with boost above 20 psi you will crack 300 rwkws and have so much better response than the 3540. some one has to say it lol, look at roys he uses a td06 on a 20 and that thing is wicked, not even a built engine and manages 260 or so, i know which one is the better choice. but hey up to you
yup... even the baby 06 the L2 makes 265-275rwkw at 1.2bar with std eng and 256/264's and will have upto 50-70rwkw more throughout the mid. At 1.5bar with plenum and 272's it would match that 290-300rwkw and still have much more mid.... or simply get the SH 06. the 3071R is also a good option but they are soft to drive and are no match for an 06.
Im my experience there are only two choices for rb20:
td06
and HKS GT2835 0.61 52t which is the small inlet version.
I think I can speak here as I have a little experance with this , I currently run a gt3040R on an rb20 a built engine and I spent thousands getting it to flow its great as it boosts pretty early and is fairly powerful car ran an 11.7 at wsid ,while this is great for a track car its not for a streeter as when it comes on boost its wheel speen city even with perrilli P zero's and on low boost ,low boost it makes 240rwkw but the way it comes on is a rush of power from 3900rpm to 5100rpm it goes from about 80rwkw to 288rwkw so in 1200rpm it makes 208rwkw thats a lot of power for the rear wheels to hold
I would tend to agree with Roy and URAS ,from graphs I've seen the tdo6 has a lot more linial power delivery to the garrett turbos as they come on in a rush and the gt3540 would be worse than mine .
I dont drive my car on the street anymore as for one its just too wild and two with the new hoon laws with that sorta power delivery with out r spec tyres there aint gonna be any traction and in front of a cop bye bye car so my engine is coming out the car is going back to stock to be sold of and I've now got a gtr so got better chance of keeping the power to the ground . This is just my opinion but hope it helps
cheers Peter
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
