  • Replies 110
It feels like a clutch pedal :blink:
Good news. The box is fixed and it wasn't something massive. The circlip and spring came off the end of the shaft and planted themselves elsewhere in the gearbox. The shaft now has a new circlip and a deeper groove machined to sit in to ensure it's not going to wander out again.
I want to say thanks to PAR for all their assistance and quick turnaround in resolving the issue ;)
It may arrive in time to be installed for the weekend, otherwise it should be back on the road early next week.
lol, I won't be there, at least not driving. Had my third drive tonight, it's going to take a very long time for me to perfect driving manual let alone driving it hard. Excuse the fact I've had my license 7 years, I'm pretty much learning to drive all over again.
183.3fwkw. Not quite as much as I was expecting but we think a few things are restricting it a little (intake and exhaust), boost drops off to wastegate boost pretty early on. O2 sensor hasn't been sorted yet so it's been tuned without one again until that's sorted. The entire loom section for the O2 sensor has been re-wired so it'll at least work once we get it in. Also split a CV boot on the dyno, messy!
If anyone is interested in reading a little bit of my story I did an interview with car blog Obsessive Compulsive Tuning Cars:
Part 1:
http://obsessivecompulsivetuningcars.com/2...ve-for-her-car/
Part 2 to follow.
  • 3 weeks later...
Wow .. I learn't on manual, have only owned manual cars - I don't think I've driven an automatic more than maybe 30 minutes in my driving life. I've taught people to drive manual, but I honestly can't even imagine trying to learn to drive manual after mostly only ever having driven auto... good luck with it :) I think it will only improve your understanding of cars and handling - which I think is what you want to do :)
You're imagining right, it's hard. Especially since the car hasn't been running since the tune and I've got no manual cars to learn it at the moment. It's a very frustrating thing, because I can drive well in an automatic, I can drive fast and have done a fair bit of track work in an automatic and I'd say I was reasonably good at is, but this is like trying to learn to drive all over again after 8 years of having my license. I'll get there eventually but it's going to take me a long time.
Oh...and even with heavy duty clutches its not too different.
I had been on my manual license my about a year when I got the Ceffy with a heavy duty clutch, I stalled 3 times on the day I got it, and once after that reversing up my gravel driveway and that was it...When I jump in mates' cars with heavy clutches I struggle a bit, because the point of engagement is almost always different, as is stiffness, but again, bit of practice and you're all good.
  • 3 weeks later...
Woohoo, I has the Pulsar back. The problems:
  • Throttle was adjusted completely shut. No idea who on earth did that. This was the cause of the car trying to stall/stalling while backing off throttle and the cause of the rough idle.
  • Tune was using the wrong base image file - from an N14. This was causing the overfueling. It now makes 13fwkw more on the same boost - 196.2fwkw, shitloads more torque (617nm according to the dyno lol), the turbo spools much earlier and it makes much more power through the midrange. The hesitation at 4,500rpm is gone. It's quite insane to drive.
  • Hot start enrichment had too much fuel. This was the cause of the car stalling every time it was started warm.
This tune was on 16PSI, previous tune on 17PSI. More power with less boost :(
This will go in down the track when I have an O2 sensor (daughterboard with O2 sensor tune):
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
