Thanks for all the replies guys. At this point in time I only need 3 cars. If I still have mine I'll only need 2, but I don't know if I'll have sold it by then or not (need slightly cheaper transport / insurance at the moment). I'll have to talk it over with the missus what colours/styles we go for, but that's a bit further down the track at the moment.
The course has been set, we're having our ceremony at a chapel in Woodville, which is on clarence town road. We'll go from there into the City for photo's at a few yet to be determined locations, then finish at Harbourview for the reception. All up I think there will be about 3 hours of driving/waiting in the day.
Cheers.
I'll sit on the reserve list if enough cars have been found. :)
P.S. i'm getting into wedding photography as well, PM me for a quote if you haven't got a shooter yet. :)
Edited by Xmetal
  • 1 month later...
Hey guys, just giving those that replied an update. We've booked in our cars for the wedding, and we won't be needing the assistance of any Stageas, sorry. We've hired a 1962 Bentley S3 and a 1963 Bentley S2, in reverse colours which look awesome.
So thanks guys for the interest, but we've gone down a different route
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
