good thread
hijack sorry, where did you guys source your hks gtrs's from. i'm in sydney and need to purchase one asap. was hoping to get the complete kit for under $2600, am i dreaming?. i know nengun do it for $2550 but that's waiting up to a month >_<
I got mine through nengun, only took 2.5 weeks to get here so i was lucky.
  • Replies 46
Posted Images
See attached link of .64 2871R on stock bottom SR20 with 400whp. OK so its a 56 trim and it was on a dynojet with extrude honed stock exhaust manifold and exhaust housing.
http://forums.freshalloy.com/showthread.ph...ight=JWT+S3%27s
Ah your in the US. Those dyno jet things read up a bit on what we see here.
Which is right? Who knows, only used for comparo anyhow... but yeah.
Its a bit higher than what we 'see' here on our brands so that evens out with everyone else's results (in aust) of around 270-280rwkw at a peak.
Good result either way.
Ignition DVD volume 1 i think it was. Gold R33 GTST with a HKS GTRS kit,
I knew you'd say that car hehe. Its the only one thats produced the mystical number >_<
I dont think VCT poses a power restricton.
warlords graph would be the pick hands down either way. That stonking power early would make it very tidy to drive
The cam option will cost you $1000 no more to pay.
The nos option will probably cost close to that (installed and tuned) plus how much for refills, and as life dictates, it will be empty when ever you really want to use it >_<
Can you send me that link as well, would like to have a look.
pm sent ....nos is $2000 tuned fitted ,refilled and supplied with 75hp pr 56kw
Edited by WARLORD
I knew you'd say that car hehe. Its the only one thats produced the mystical number :D
Ahhh so you knew about a 300kw GTRS equipped car, trying to hold back the truth ay >_<
But yeah i know what you mean, above something like 270kw its a mission to get the numbers out of it but i still think with a bit of mucking around it isn't as hard as it seems, ill try to continue this magical test of 300 out of the GTRS :D
Yeah im really impressed by warlords graph, if i had that power i would be very happy indeed.
Actually, I'm in Perth WA but frequent the US forums for info. Yeah dyojets probably read 10 - 15% higher than our Dynamics. That said I've also seen by brothers SS Commodore car read 500 rwhp on a dynamics in Sydney and 450 back here in Perth. So obviously calibration differences btw dyno's of the same ilk.
The results will be much the same as the HKS item mate.
Might be a minor variation, but for all intents and purposes its near enough
so why is it that everyone calls it the same thing, yet everyone i talk to says the 2871r will only put out roughly 240rwkw, yet the gt-rs is able to pull >270rwkw. i've searched and searched, sent PM's but i still don't get it :banana:
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
