  • Replies 94
Posted Images
good luck !
Up date after the races
The car having some boost isues, could not get over 20psi. I think its the cheap Ebay waste gate, but on 20psi I was able to run 7.1sec in the 1/8. Best 60ft the car had for the day was 1.50 sec. Then "Bang", i broke the outer CV joint in the rear. The car is HOOKING!!!!
So i now have to resolve my boost issues and change the CV joint. I will look into some performance ones.
what you can do is get a gtr rear end, strip all the arms, diff, cv's and bolt that to the existing cradle in your car now.... you will need a custom tailshaft
the diffs are mechanical, also are a 4.11 ratio, the cv's are a shitload thicker and stronger, this is what i have in my rb26 powered s15, yet to test but ive had the cradles side by side and the difference in everything you will swap over is heaps better that the s14 stuff...
waldoforce You don't have gtr diff+axles+hubs? Was a miracle that you run with gts-t or silvia rear end!!!
I have gtr diff,axles,hubs and the center shaft!!
You need hubs because gtr axles are thicker!!
You run only 1/8? Not 1/4?
Any issues with gearbox?
Your twin plate work good?
Fotos? Videos? :P
1.5 is very good :(:)
I have Mickey Thompson 26x11.5x15 in 8" Weld Drag lites wheels!
What rear shocks you have? Do you have any aftermarket links on the rear? Bushing?
Do you have skinny front? I have 18" front for the time with 8piston D2 brakes :wub: I don't know what to put there..
Fotos? Videos? :P
enjoy! Oh take some time and look the time slip in the vid. Thanks
I have R33 GTST diff, axles, the whole rear sub frame.
I will look into the GTR axles and hub, thanks.
No issues with the gearbox as yet and the twin disk clutch is still holding.
The red 180sx in the vid is using almost the same tires that you have (26*11.5*16 ET Street drag) , but he has them on the twin turboZX 8.5" rims. I am using MT 26*10*15 on 10" weld rims.
In the rear I am using stock S14 shocks, with lowered skyline springs.
Yes I do have adjustable aftermarket links in the rear, with polyurethene bushing in the spindles. I also have a set of aluminum rear subframe spacers
No i dont have skinnies up front. I have 18"s awell with the factory skyline brakes and rotors all round. You will be fine with them. I have seen many 10sec cars without skinnies up front.
Thanks, I will definitly look into this. I need something that can handle my hard launches.
Thanks again
1.506!!! Very very good ;)
But 7.1 isn't :dry::( 600whp s14 must do something like 6.5!! Try more when you fix your boost problems ;)
My tires are better than your friend's... I have 15" so quite more sidewall!! My tires is et street drag too.
Don't forget that your need also gtr hubs.
What times did your friend and what horsepower he has?
I will put also a line lock for easy burnouts!! :D
My target is to do very low 10sec in the 1/4 drag races!!
We have a race at 13 September and I hope to have my car ready to race :)
But 7.1 isn't :(:) 600whp s14 must do something like 6.5!! Try more when you fix your boost problems ;)
We have a race at 13 September and I hope to have my car ready to race ;)
Thanks for the heads up on the GTR hubs.
My friend makes about 480whp and his best time to date is 7.1sec in the 1/8th.
You are right, at 600whp I should be able to do 6.5-6.7sec, but I am not the best of drivers :dry: . We have an event at the end of this month. I will have the car ready for that.
  • 2 months later...
The car finished!
We had a problem with the wastegate.. the valve was all the time semi-open and we didn't undestand it.
With stock ecu and mafs was a pain. The car was very unfriendly and difficult to drive but maybe the problem was the semi-open wastegate.
We did 11.7 with 1.3bar only and the clutch slipping a lot!! But I wasn't sure that it was slipping...! Ah and 1,565 60foots!!! And without launch control!!!
So we take the desicion to put an Apexi Power FC D-Jetro! And we check the wastegate if was good and we saw the problem.
So when we put the power fc the car was like a stock car!! Very friendly!! Still with base stock map(ofcourse only for vacuum driving)!!! I was so happy when I put the power fc but as I said maybe the problem was the wastegate. We burn two z32 mafs while we tried to finish the car with stock ecu so I am very happy now with the maps and I have cool engine bay!!
We was on the dyno.. at 16psi 540flywheel hp with 8500rpm limit and the clutch slipping a lot!!! The afr was 11.0!
So we leave it there... with 2.2sec 60foots and with 16psi boost and with this bad clutch the car did 12.5 in my second drag race! I go for race only for fun as I had slipping clutch.
I put also Splitfires just to be sure.. Gizzmo launch control system with tach recall shift light.. Denso Iridium IK24 plugs..
When I will buy an overhaul kit for my OsGiken Twin plate I will go again on the dyno. Maybe with IQ27 if I will have money :cheers:
Also I use 100octane pump fuel. But I am thinking to add 1/5 Vp Import for my high boost runs. How much high? I don't know yet :D
Edited by GreeceS13
any update ?
Thanks everyone for the info on the GTR axles and hub, they work like a dream. I am now hitting 1.4s 60 foots, best to date is 1.47sec. Also, I have been able to get the boost up. I am pleagued with a faulty waste gate, but was able run 26psi. The car did 7.003sec in the 1/8 on a test and tune night with minimal track prep. We have an event today. I will keep you all updated.
Hey waldoforce,
can you post up some pics of your s14, are you also able to post some spec's on turbo, cams, pistons?
cheers
dan
The turbo is a garrett T04z with a 70ar back housing. The motor has factory pistons, and I am using Tomie pon cams 260 degree.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
