  • Replies 94
Posted Images
What engine mounts do you use?
Tell me please all your specs!!
Do you have any fotos of your project?
Here is a vid of the car when it had 450whp, and best 1/8 et at this hp level was 7.023 seconds
I have customed engine mounts, but you can buy a set from Mckiney Motor Sports
Presently I have the following mods:
Stock internals RB26
Stock head gasket
Tomie 260 pon cams
Garrett T04Z turbo with 70ar back housing
AEM stand alone with wide band O2
AEM 3.5 bar map sensor
48mm waste gate (cheap ebay)
83lbs seimens injectors
dual 255 walbro pumps
huge 4 inch thick intercooler
stock rb26 intake manifold
nismo GMax twin disc clutch
I am still doing some fine tuning on the car before i run the 606whp tune. I hope to run a 6.7sec.
  • 1 month later...
hey Waldoforce (Congrats).... I had in the past a Supra 2JZ-GTE with similar mods and AEM EMS with 750whp stock internals.
I just want to be sure how many miles did you use your car with stock internals with over 600whp, because I had read too many things about the oil pump failure and I am thinking on almost same mods that you have but Borg Warner S372 intead of your T04Z turbo.
Which oil are you using ?
How many RPMs did you change between gears ?
  • 3 weeks later...
Hi, sorry for the late respond but I just came across this thread.
I am presently running a S14 Silvia with rb26 with stock internals rb26 except for 260 degree cams. To date i have made 606whp, and i am using a garrett T04z turbo.
Do you run 5 speed or 6 speed ?
Very intersting!!
606whp at 26psi with very little mods!!! And with smaller turbo than mine..!
I don't finish my project yet..
I also bought a TOP SECRET SINGLE THROTTLE INTAKE with q45 maf!! :(:):blink:
Are you ok with your Nismo twin plate? How many miles and hard lanuches you did with your twin?
Do you thinking for triple or you are happy with it? Do you suggest me to stay with twin?
I am not sure if my twin can handle the power.
Happy with your skyline gearbox?
What diff you have?
1/8 mile 7 sec means lower than 11sec... something like 10.7!!
UNBELIEVABLE GOOD FOR 450whp!!!
With what tires?
How much you did for the 60foots?
So with 600whp how much I will do?!? :):D :D
And with drag wheels with Mickey Thompson 26-11.5-15 (275-60) ?!? :D :D
SX rulez!! :woot::D
Edited by GreeceS13
Very intersting!!
I also bought a TOP SECRET SINGLE THROTTLE INTAKE with q45 maf!! :whistling::D:P
What diff you have?
With what tires?
So with 600whp how much I will do?!? :D:D:D
And with drag wheels with Mickey Thompson 26-11.5-15 (275-60) ?!? :D:D
SX rulez!! :D:P
any update ? did you tested ?
I havent ran the 600 tune much, only 4 1/8th passes to date. Its true that the RBs are plagued with oil pump failures. I am waiting on a ATI damper pulley (600 plus unit) which will help prevent oil pump failure. It also helps not to rev the motor past 8400 rpms
A friend on mines is using a S474 on his Rb25. Its a lil laggy but it hits hard, but he is still tuning.
I am using 4 quarts of 20w50 Castrol oil with 1 bottle oil lucus oil stablizer.
I shift my car at 8100 rpms, and i drop about 2000 rpms between shift.
  • 1 month later...
GreeceS13 ...... did you tested ? any videos ?
I tested the car using a pair of Mickey Thompson 26*10*15 on 10" weld rims. I blew the factory LSD and da car just spung 1 wheel.
I then weld the stock skyline diff and went back to da track. Unfortunitly the clock wasnt working, but i will say this "OH MY GOD" the car leaves the line like a bat out of hell (2 stepping the car and leaving the line with 18psi of boost). I ran a turbo mustang that run 7.3 sec in the 1/8 and beat him convinsingly, and I was at 20psi of boost.
There is a event coming up on the 31st of this month, so I will have some times and hopefully a vid of the 26psi 600whp run.
how much weight your car ? I am worry about the 3rd gear problem on your stock 5 speed tranny with 606whp....
I don't finish it yet... :D:bunny:
We have summer in Greece now and it is great time for other enjoyments :(
But I have a drag race to run at 13-14 September and I hope to be ready to race.
So I will inform you about the car..
For the time I don't hear the engine to work yet :laugh::down:
I couldn't say for sure what the weight is, but the car is a full body s14 with full interior. Plus my weight is 265 pounds. I would guess about 3300 pounds with me in it.
I have also heard of people breaking 3rd gear with big power on the R33 box in a Skyline. I hope by having sprung hub twin disc clutches (Nismo GMax) will help absorb the SHOCK in 3rd gear. I will see what happens on August 31st, when i really push the car :banana: .
I will keep you all posted.
I have also heard of people breaking 3rd gear with big power on the R33 box in a Skyline. I hope by having sprung hub twin disc clutches (Nismo GMax) will help absorb the SHOCK in 3rd gear. I will see what happens on August 31st, when i really push the car ;) .
Are you running RWD or 4x4 ?
you're OK up to 650whp if is RWD.... my case is worst only 500whp on 4WD.
650whp, well thats good to hear.
Thanks for the heads up.
Oh i just installed my 600plus hp ATI damper pulley, now I am ready for the big races this weekend.
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
