The cooling area of my R32 GTS-T has gone to bits.
1) When i run my car no water leaks it goes normal...when i park it and switch it off and say after 15 mins of cooling down, water begins to trickle from te centre of teh bay, so its more than obvious its the pump right?
2) The collant tank is the first to drain out, then say after a day or 2 the radiator begins to drain.
What the hell is going on man? And the water that i refill turns to smudge like brown and orange, i think there might be a blockage thus causing the discolour?
Help us out here fellas it would be much apreciated.
Thanks.
https://www.sau.com.au/forums/topic/202393-whats-the-right-coolant/
You could do a radiator/coolent flush, then do a pressure test on the radiator to make sure its not leaking, then check the hosing/pipes, make sure they are secured down with hose clamps.
I have not seen brown/orange colour coolent b4, Red (usualy for Toyotas) and the rest is Green. I use Techteloy 100.
Edited by (00)SKYLINE(00)
you mean it like leaves a puddle under the car like its coming from the centre of the bay? could be a pin prick hole in one of your hoses, i had a similar thing. would only leak once the car was warmed up, building enough pressure to make the coolent seep outta the tiny hole. was one of the heater hoses located under the plenum.
yours could be the same, maybe only the hole is smaller then mine was and needing more pressure to make it leak? turn the car off, the coolent sits in the still hot engine block with no circulation, boils that little bit more making the extra bit of pressure, leaks, then cools down sucking coolent back in from your overflow bottle/coolent tank and youre none the wiser..
just a thought anyway.. :S
i could run my car without the radiator cap screwed on tightly, allowing no pressure to build up and it wouldnt leak the coolent out the small hole. not recommened for driving but only just a test on the spot. maybe you could do something similar?
shaun.
Thanks.
if you dont maintain the coolant it eventually turns light green then can get fowled and get sludge in it and brown a bit.its important to flush that radiator if its dirty and replace new coolant mix.leak might be just a hose etc or a join.so gotta get there an see where water is going from,new pump will mean replacing it.better sort it sooner than later.
I had the same deal on my 31...
It seems like its coming from water pump???? i put some seal up in it just till engine is done. It worked well.
But i only did that cuz i'm building a engine and dont want 2 waste time on a sh!tty rb20, it would be the water pump gasket, or actual pump itself.
So if your keeping the engine, inspect and replace, when your there have a look at the shape its in "corroded or scummy" run a good system flush and have the radiator done aswell, cuz there is no point flushing your system and leave the rad alone.
mY 2C
Wow, you've got a chicken in your cooling system?
The easiest way to check for a hose failure is to get the car warm & with a pair of gloves on squeeze each of the hoses in turn to see if they do in fact leak under pressure.
Or, if you are Welsh, leek under pressure.
Thanks for the info guys, very helpful. I think it needs a good flush because the water looks like its mud. I have noticed the ehating going up now aswell.
Another 2 questions.
1. My brother in law told me not to put just any coolant in there ,that i should read the manufactures manual and see what its compatible with. He told me that the brown sludge is not the coolant but the corosion the coolant is causing, and that anit freeze adnti boil stuff you can buy from K-Mart is hazardous to the car. Anyone back this up? And if so, what coolant do you reccomend. He told me to put Toyotas Coolant Inhibitator that you can buy from Repco.
2. Anyone can direct me to a website that shows step by step how to flush my system? Pictures would be helpful.
Thanks guys.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
