ok peeps the story goes like this
i wanted to play call of duty online yesterday, and it said '' that i should check my internet settings''.... so i did and everything looks ok, BUT when i run a test for my I.P ADDRESS it says timeout?????? and at the bottom it says PRIVATE NETWORKS ONLY or something like that
is there something i am over looking? is this the problem?
(and yes the internet works on my pc but not on the PS3)
WHY PEOPLE WHY? any help would be great
cheers
https://www.sau.com.au/forums/topic/202415-ps3-internet-problem/
I run my PS3 via a wired connection as well but I never let it automatically assign the IP and stuff. I would recommand in your network settings on the PS3 assign it an IP address and enter the information manually. Although I run Bigpond internet here so my connection was alot more of a pain in the arse to setup because I had to change the IP address of my router so it wouldn't conflict with the IP address that the bigpond router was trying to assign. Also put your PS3 in the DMZ zone of your router so you don't have port issues with playing games as well.
On your PC if you goto "Start" then "Run" type in "cmd" and that should bring up your command prompt.
In the command prompt type in "ipconfig /all" and that will bring up settings for the PC which should have all the info you need for the PS3.
On the PS3 assign it an IP that isn't being used by your PC or any other PC in the house.
To get the subnet mask etc etc it should be listed when you typed in "ipconfig /all" on your PC so just copy that data onto your PS3 and see how it goes.
If you have any trouble let me know. By assigning the PS3 its own IP address that way you can enter that IP address in your router in the DMZ and not worry about the router assign the PS3 a different IP.
damn that sounds hardcore, all i know is turn on computer and press buttons preety much LOL.
but yea i understood what you explaned so ill give it a shot tonight
my friend used a wired connection at his place and it worked stright away EVEN BEFORE TRIED IT AT MY PLACE could this be a problem?
yea i am wired to optus
thanks alot mate ( that must of takin ages to type up lol)
Actually just double checking is it being connected via a router or straight from the optus modem?
There is 3 ways that come to mind to get an internet signal via an ethernet cable to the PS3 let me know which one you have.
1. Cable modem (in your case optus modem) plugged directly into the ps3 via ethernet cable (No network access just internet)
2. Cable modem being plugged into your PC (via usb or ethernet) then lined out via ethernet to the PS3 or a switch (PC needs to be on for internet)
3.Cable modem lined into a router via ethernet cable then cables from the router goto the PC and PS3 (Internet and Network Access. Prefered Method)
[edit] Always willing to help out a PS3 or skyline owner.
Edited by Triptych
Make Sure your not using a Cross-over cat 5/6 cable. when your sure u have right cable. turn off your cable modem (unplug it), and leave network cable unplugged ( but leave ps3 end pluged in). turn modem power on (plug it in), wait till power light on modem comes on, then wait till recieve light comes on, then plug network cable in. then go to your internet connection setup, chose wired connection-yada yada. select Automatic setting for everything. Once it has configured its settings, it should work. i know quite a few ppl with optus cablenet with PS3's and none have had a problem. If this doesnt work than ill bet your PS3 network hardware is Cactus. Take it back and get another one.
P.S dont even bother with Wireless as it is Insanly slow compared to Wired.. my PS3 downloads way faster than my PC. 1.2MB/s WOOT.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
