Item:R32 Factory Option Car Cover
Age:14 Years
Condition:Relatively unused, no holes, all straps and buckles in good condition, could do with a light wash
Price:$150 ono
To Fit: Supplied by Nissan for R32 coupe's but could fit an R33 as well from the looks of it
Comments:Genuine Nissan factory option part, pretty hard to come by.
Item:R32 GTR Factory Option Rear Strut Brace
Age:14 years
Condition:Stickers on brace starting to fade, but still legible, strut has never been in an accident, so is structurally sound.
Price:$150 ono
To Fit: Should fit any R32 coupe (had it on my GTS after the GTR). Never tried on a 4 door, so not sure if it'll fit.
Comments:Another factory genuine item, not a $40 cheap chinese POS that'll probably buckle if you drop it.
Contact:via PM or by posting in this thread
Pics soon.
Is this the same item as what you find on a V-Spec?
I'm sure it doesn't make a difference, but if its the same I'm sold.
Pics as promised:
As you can tell the cover's pretty much suited to only coupe shaped R32's and possibly R33's.
There's been quite some interest in the car cover all at once, so whoever offers the most will get it I suppose.
