Hey guys,
Looking at installing some interior neons (don't mock it, i'm extracting some more power from the engine to counter act the added rice :D ) but i want them 2 turn on when I open the doors. Where is the sensor in the door that turns the interior light on? I'm guessing I dont have to run wires through my roof to achieve this. Any help would be appreciated.
Rhys
https://www.sau.com.au/forums/topic/202539-door-open-sensor/
I 'm quite sure it's inside the door locking mechanism, but correct me if I'm wrong.
It's gonna take a bit of planning and enginuity to put it all together
I installed my neons and just added a switch
Good luck with yours
its easy, if you want the neon to turn on when you open your door and turn off when you close it
just connect it to your roof interiror light by connecting the wired (cant really remember coz i done this last yr)
but connect it to the roof light and switch it to "door" so everytime you open your door it should turn on so on with closing the door.
i use velcro and stuck it up the roof..hope that helps = ]]
P.S i got the blue neon from supercheap and it wasnt that bright worst then your normal interior light
counldnt see Shi* soo i when back to normal light ^__^
so what does that mean? I'm not the best when it comes to electronics unfortunately!! I'm a f**king mechanic for shits sakes!! How bad is that!!
means if you tap into the switch - you need to connect the switch to the Earth side of your lights, then supply the light with constant +ve power
that way when the switch earths out, you get light
i think the light switch is down below the latch on the pillar part.
only down side to this is that they come on whenever you open the door. i have a blue neon as the interior light in the pulsar, but i also still have the standard light (helps when reading maps, looking for shit, etc) the interior light still works off the switch so i can have the door open and not have it on, but the neon is on whenever the door is open.
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
