  • Replies 96
Yeah, me too. I usually go up the Coast on Thursday nights, but seeing as I'm going up there for the weekend on Friday anyway, there's no point going there only to come home and return the next day. I love Thai food too.
Woohoo!!!
4-day work week and great thai food as well... How good is that!
Lots of good R32 GTR minds for me to pick :glare:
13 people! We might as well just book the restaurant out completely!! I hope they have room for us when I ring up to book tomorrow morning :laugh:
I'll try to make a booking for 8, and see how we go.
If everyone can please confirm attendance, that would be great so I can amend the booking if needed later in the week.
This isn't usually an issue, but Orchid Thai is a pretty small restaurant and I don't want to overbook it and cost them potential business :ermm:
you guys have just reminded me I've got a short week coming up too, and as a bonus Duncan's going to be left home alone on Friday night with the kids!
makes thinking about getting up for work tomorrow a bit more bearable :ermm:
OMG! I hate you merli.. push it back another night!!!
I get home on the friday night.. and I'm right down the road from this place! I can get drunk and stumble home!
PUSH IS BACKKK!
Love D_I_F!
PUSH IS BACKKK!
Love D_I_F!
I can make another booking if you want? Table for one on Friday 1st Feb? :(
Okay, looks like we already have 8 confirmed.
Merli, Dundan, Kel, Steveo, Nick, Nick, Jon and Mal.
Any more confirmations, and I'll change the booking on Thursday morning :(
Any more confirmations, and I'll change the booking on Thursday morning ;)
Thanks Merli :)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
