POSTING UP FOR A FRIEND SO PLEASE CONTACT HIM ON THE NUMBER BELOW AS I DO NOT CHECK MY SAU PMs OFTEN. THANKS :D
Hey all,
I got these only 2 weeks ago but i now have the opportunity to get a set of WedsSports at a bargain price. No use having two sets so im selling these off. These are still brand new and have yet to be trial fitted to any car. They havent even been removed from boxes! Only 1 box opened to take pics.
Work Emotion xd-9
18x9 +20 in Bronze.
Item: Work Emotion xd-9
Age: Brand New
Condition: Perfect
Price: $2000
To Fit: - (What car)
Contact:0423 374 938
Comments: Yes, I know this is on NS.com (http://www.nissansilvia.com/forums/index.php?showtopic=277653&st=0&p=3819039entry3819039), I'm posting the rims up for a friend.
hey all,
these are my wheels - forgot my username and pw until i realised i could get an email re-issuing a new pw.
if there are any questions, feel free to shoot me a sms/pm.
These offsets are ideal for GTR, let me know if youre interested!
cheers
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
