Just a quick question.
I have just gotten my hands on a rb30det (loom, ecu, turbo all there), with rb25 gearbox, and was planning on stuffing these into my r32 manual gtst. Having basically very little knowledge, and no experience in doing this conversion, I was wondering whether there are any issues with this proposed conversion, or does the engine fit straight in, like a rb25 would?
I am planning on ripping out the rb20det and gearbox out myself, respraying my engine bay and then towing the car to the shop that is going to do the conversion. but to save on time, and any potential hassles, was wondering whether i would need to provide any additional bits and pieces for this. I have purchased some new engine mounts, but apart from that, i can't think of anything else that they might need.
Any help on this would be appreciated, as the car will probably be going in on either monday or tuesday.
Cheers
https://www.sau.com.au/forums/topic/202546-rb30det-into-r32/
well that's good news. what about all the mounting and bracing underneath? all lines up fine? already got a front facing plenum on it, so should hopefully have no worries. will have to see about the high mount turbo though. might need a new manifold for it
the solution is to modify the Rb20 engine mounts (metal brackets) and cut them down some 20 mm then reweld them up, this will lower the engine to a more desirable height, however the sway bar will foul and the sump will be lower then the crossmember, so spacve the bar down and fit a bashplate and these issues are then nothing to worry about.
I had to remove my strut brace, have a stock 25DE plenum on there and it rubs slightly on the front corner and also slightly on the timing belt cover.. I spaced the back of the bonnet up 10mm so it doesnt try to buckle the bonnet every time I shut it..
Forward facing plenum will go on with the new turbo, all measurements for the GT35R high mount appear that it will clear as it will sit just below the crossover pipe. Will likely "massage" the timing belt cover slightly, don't need to gain much.. 5mm maybe.
Does the 30 have all the ancillaries bolted on? if not you'll need to modify the power steering pump bracket (cut the top boss flush with the lower two), other than that I don't remember anything else that needed modifying (apart from shuffling all the pipework so the bonnet would close!).
Edited by bubba
RB30 did not end up fitting. Mainly due to the design of the front facing plenum on the thing. Stuck up by a couple of centimetres. Could have had another plenum fabricated, but that and the retune would have put my budget out by a fair bit. So rb25 it was. Car will be back on the road on monday at the latest. Trying to source a bloody pfc at the moment that is reasonably priced is proving impossible as well.
also, if somebody in the brisbane area has a r32 2way they are willing to sell, pm me :P
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
