Just wondering what oil pressure a R32 GTR will run at idle and revs when hot and cold. Also what eng oil temp do they usually run. I thinnk my oil pressure is a little low and the oil temp seems to be alot higher than it usually has been. oil temp is up around the 75 to 80 deg even on cool nights. It has a big oil cooler on it. The oil pressure is below 4 kg/cm3 at idle when cold and is back to near nothing when hot. I havn't checked it with a mechanical gauge yet but will be maybe this week end.
https://www.sau.com.au/forums/topic/202552-r32-gtr-oil-pressure/
I just started a brand new engine (with forged internals etc), and at idle when cold the oil pressure is about 6.5kg/cm3, and drops to just under 4 when hot. Ive only idled it around the local street because its untuned though. The oil temp doesnt go above 80 degrees when hot, with a large oil cooler. Both gauges are greddy expensive ones.
Shaun.
  • 2 months later...
dont listen to the ppl tellin u to change ur oil. its not ur oil. its the sender unit.
mine also did the same.. i shit myself real bad when i first noticed it.. it was @ 0 @ idle.. but after a few days i noticed that even when its on 0.. the light doesnt come on.. u know why??
because they run 2 seperate systems. 1 fails.. the other doesnt. put an aftermarket gauge on it and ull see the difference :cool:
  • 6 years later...
Hey All, I think I need some similar advice to this post.
I just bought a GTR in QLD that I have driven back to Melbourne over the last few days. I never really paid any attention to the oil pressure to begin with, but noticed today it was on zero - but the car seemed to be performing fine - great even! it did over heat on me yesterday somewhere in central NSW but it seemed fine again after a rest. I have noticed it seems to be running hot, & im not sure why.
When boarding the boat we were in the waiting line with a lot of idle, stop start etc with the engine getting rather warm. The oil pressure light then came on, with it barely idling, coughing & spluttering. I turned it off for a few minutes, then it was fine again & didn't miss a beat getting onto the boat.
I write this now sitting in the bar with a beer, freaking out! im hoping the oil pressure issue is related to the over heating, & that is hopefully something simple like the thermostat?
The motor has been rebuilt & I have all the receipts for it, I am living in hope its not the motor...
what should I be checking?
Im thinking if oil pressure light came on while it was spluttering might be that it almost stalled itself and as such dropped oil pressure enough to set off the light, but probably kicked itself back to life.
Have you checked the dipstick? Overheating could be a lot of things and it will need to be narrowed down.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
