Yea i had to do it to change SI spoiler to SII.
Dont have time to write it up here but ill put it up tonight if possible.
Basically open your boot. Pull Fabric back and find the nuts to undo. i think there is 4. if not then its 2 (did it ages ago)
once they are undone then you have to slide the spoiler back and forth to get it off the clips. This part was to fiddly and i ended up breaking a couple of them. thats basically it.
Ill put up pics of back of spoiler thats off to show ya what i mean if i can find the time
Easy as, take off about a dozen clips(very easy to pull off with flat head screw driver). then use the flat head to take of 4 plastic grommets off. 2 on each side. then remove 2 screws (10mm) on each side. dont worry it wont fall off. then just simply fiddle with it a bit and your done
:D EASY :)
had mine off not long ago.. once youve undone the four bolts, put both arms under the wing and lift up as hard as u can... the thing is surprising strong and even though u will have to jerk upwards quite hard nothing will break
