Whether Nissan brings them in, or only private importers, doesn't make much difference to prospective buyers.
As long as they're available here in reasonable numbers within a reasonable timeframe.
the same damn government that's got one of the best import laws for a country with its own automotive manufacturing industry?
No, the same govt whose protectionist taxes, duties and double taxes increase the end cost of such cars as this. I wonder what the price of an R35 would be if the govt didn't hit us/manufacturers with all these taxes.
Cheers for that. That was what I was missing. RAWS can only do used cars so we are back to 18 months of waiting to see what Nissan does.
these two docs might be of help:
http://www.superfunhappysliders.com/images...y_flowchart.gif
http://www.superfunhappysliders.com/images...bilty_table.gif
From memory our current emmisions requirements are equivalent to Euro 2 via ADR79/01. Since the 35GTR will be sold in Europe it will obviously have to pass Euro 2 standards to be elligible there. The currently available (JDM) 35GTR may only pass the Japanese standards, not the Euro standard. But I don't see that as an issue as it will have to eventually, so it may simply be a matter of uploading or changing the ECU and perhaps fitting some Euro standard (fast warm up) cats. None of which is a big deal. Obviously if it goes on sale in Australia then it will simply be a matter of duplicating what is done to the Ozzie version.
As an asside, the major problem with passing Euro 2 emmisions that I have seen with JDM vehicles (M35 Stagea being one of them) is cold start and run. The cat/cats simply don't warm up fast enough. When the engine is warm (but not yet up to running temperature) they are OK, but only just. Once the engine is up to operating temperature they have no problems at all.
Personally, I will be waiting until the 35GTR's are on sale in Europe before I order mine.
Cheers
Gary
Protectionist taxes (duties) = 10% (it used to be 42%)
Luxury Car Tax (on the value over $57,123) = 25%
GST (same as on everything) = 10%
So the real "protectionist taxes and duties" are only 10%, as locally produced vehicles are subject to GST and the LCT applies if they are over the cost threshold just the same.
Cheers
Gary
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
