  nitemare5 said:
it's not really about the power gain, it's about protection from lowering the intake temps.
True, cos people found that stock intercooler are too small, and after a few times of acceleration it starting to loose its efficiency. It's even worse if you run higher than stock boost. I think my car on dyno last time only did about 2-3 runs on 9psi and the stock intercooler started to get heat soak :P.
Personally I would go for the standard pipe return way rather then over the top of the fan way, using the standard returns just makes it look neater and you don’t have to worry about cutting the hole for the pipe to go through and trimming your fan blade for it all to fit.
Really it’s up yo the end user and I don’t see that much power difference between the three different cooler layouts. It would only be a couple of rwkw either way, if that.
I agree.....and that couple of rwkw difference are usually towards the top rev range. I don't need that as I'm not trying to win a dyno comp.... and I don't drive my car on the street at a constant 6500rpm :D.
I prefer the 120 degree bend at the throttle body style, no fan shroud trimming, less heat soak and shorter pipe for better throttle response. :D
I started this thread a long time ago and am surprised it's still alive and kicking. I'm sure i've posted what i ended up doing somewhere on this thread but i'll clear up some points about aftermarket piping.
I fitted to my R33 GTS-t the TRUST V-SPL FMIC kit, which uses non-standard piping routes.
1) I did not cut any fan shroud/blades at all to fit the cooler piping which goes to the throttle body.
2) Yes, you do have to cut a hole in the side of your inner driver's side guard, as well as a little bit of grinding away of the lower inside ends of you bumper support. (Hard to explain in words but it was a piece 1cm x 4cm at end end to square off the roundish bumper support to fit the end tanks of the cooler in)
3) You have to move the horns but with this, all you need is a little "S" shape braket to move them closer to your radiator thus fitting between your cooler and radiator still.
4) You will need to modify your front bar accordingly.
5) Everything else bolts straight up.
As SK said, the 120 degree bend trick is the shortest route (with the exception of a Greddy inlet plenum) but if you're only worried about cutting your fan blades, then this isn't worth the time or money to fabricate in my opinion as cutting them isn't necessary if done correctly.
Hope that helps add to the discussion.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
