Also a heads up if ur gonna use sikaflex...when spreading evenly and in the most cleanest way, use ur finger with spit on it, first date lubricant (spit ;) ) repels sikaflex good. (not that i break enuf things to know this.... :D ) White spirits cleans up excess sikaflex pretty good.
Thank you for the info guys. :) Will try out the sikaflex + doubleside tape :( + Hand :(
vince are you running 12000k rite? or u switched them back to 8000k? why dont you use some stickerflex ?
9000k now.
silcone is shit for what you want....enough vibrations and it will come off....will find that alot of stuff on your car is held with sickaflex....r32 tail lights are sealed with sickaflex for example.
went to autobarn and found out that sikaflex = silicone made in Japan ? + more expensive ... What's the different compare to normal silicone ?
Sikaflex is not like silicone, Silicone dries to a hard but flexible compositon and due to flex and expansion/contraction eventually looses its bond, Sikaflex doesnt really dry out, it stays like a goo and seals really well I have used it extensively on all types of applications from electrical to plumbing, it shites all over silicon.
had tried out the sikaflex... can't complain at all.. very sticky.. a pair gloves is a must....i still got some stick on my hand after two days.. :D
Hahaha..yeah it happens. You'll find that using gloves sometimes is worse off...unless you have a whole box of them right next to you.
