Hey all,
I have a 1989 R32 GTR, stock except for...
900hp Walbro intank fuel pump
2x Greddy filters
Cat back HKS Super Dragger 4" exhaust
Grounding Kit
Tien Coilovers
Front and Rear Strut Bars
They are all installed on the car, i have sitting in my room...
Profec B 2 Boost controller and a Power FC computer and a extreme double plate clutch & flywheel. The engine is only 88,000kms old in going great.
I will be getting sometime soon Splitfire D1 Coils and leads and new plugs.
I am also in the market for sme new turbos....dont know which to get though.
As you know now i want around 400kw atw, but dont want a big single turbo system at the moment.
I have a choice of...
2x HKS GTSS Turbos or 2x Nismo R1 Turbos - the reason its between these turbos is because they are available as a bolt on kit for a GTR, so there is no screwing around getting custom shit made up and so that i can do the work, as i am a mechanic in the RAAF. Get the Power FC installed and tuned by boostworx in adelaide though :D
Which one's do you all reckon i should go with :) . Has anyone used Nismo R1 turbos before as im findin it hard to find info on them, but i can get a good price for them. On the other hand im not t sure GT SS will make 400kw atw.
Any help would be great, thank you.
Doug
Edited by GTR747
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/
Im not tryine to rain on your parade here
but
400 At the wheels on stock internals = Bang
GTSS' are good for around 330-340rwkw
R1s a little bit more from memory
And you will need Lots and lots of dollars to get anywhere near that power figure...
Injectors, Cams, AFMs Dump/Front pipes, Crank collar, Forged Internals etc etc
Maybe you have the budget, But as they say "If you have to ask you cant afford"
Not sure If any of the big power guys will tell you how much they have spent. But its not cheap.
Your Best off going to an engine builder/work shop in your area and straight up say. I have this much to spend, how fast can I go.
Cheers.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596832
First question: Why 400kw? Is this a magical number or do you have a specific reason for chasing this kind of horsepower?
You will need something along the lines of HKS GT2530's or GT-RS's and a decent amount of boost, not to mention a stack more mods, decent cams and possibly some head work to achieve 400kw at the wheels.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596859
what he said...2530's need 2bar of boost to do 400AWKW so its really stretching them too. GT-RS turbo's are the king of bolt on turbo's...currently powering the fastest bolt on turbo GTR on the planet.
save yourself some headaches, heartache's and lots of time and stress. Sell all the gear you have and buy our car...simple 500kw all day every day at a lowly 25psi.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596878
^^ LOL Twoogle FTW
Who has read that article in the current Autosalon Mag by Iain Kelly about how all Aussie import drivers care about is dyno figures and peak power outputs.
Not how the car accelerates out of a corner or the amount of mid-range grunt.
Id rather have a super responsive 250rwkw over a mega peaky 400 any day.
What do you want to use the car for GTR747.
Judging by your forum name its Drag Racing.
Edited by zebra
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596883
Add to that the 6-8k bottom end :D
Easily 20k to get you going.
I think you need to do a LOT more research GTR747, to not know HKS2530 are a bolt on option, and are the best option for 400awkw... shows there is a very big information gap.
Have a read of the Dyno sticky thread and a few of the links in the FI Guide.
They contain info on setups and what you will need (parts wise) to achieve that power.
Whoever is doing the numbers for the bottom end will also play a key part in its survival at over 650hp.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596888
Mainly want the car responsive but can hold power throughout the rev range. Gonna use the car on the street but want to be able to hold my own around a track at a track day or soforth.
I think im giving the impression i dont know what im talking about here, thats not true. But to tell you the truth, i was unsure what sort of power these 2 kits were capable off, now im getting an idea.
400kw was really just a throw around number, just wanted to see what you guys thought abuot my - A nice, quick responsive GTR - i thought that was obvious when i specified my turbo kit choices. As zebra said, i would rather a super responsive 250rwkw gtr than a peaky 400rwkw gtr.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596897
2530's are by no mean a 'peaky' turbo, but the sheer cost of 400awkw vs a more easily achiveable 300-330awkw is phenominal as it can be done on a stock motor for a start.
GT-SS (or equiv) gets my vote if you revise the 400awkw to around 300-330rwkw, response as stock, pulls to redline.
Loads of info about on them, here is a start.
http://www.skylinesaustralia.com/forums/Rb...tml&hl=gtss
http://www.skylinesaustralia.com/forums/Gt...tml&hl=gtss
http://www.skylinesaustralia.com/forums/Re...tml&hl=gtss
Also plenty of HKS 2530 information around and who has achieved what etc.
(and their equivs you'll find if you read the 2530 threads)
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596934
R31Nismoid - Thanks alot for your help brother - Im reading as we speak.
Of course 400kw is gonna cost to maintain, no questions about that.
So your voting for the GTSS kit then, alrighty then, so far that kit is looking like the one to go for.
Ill be more than happy with a responsive 300rwkw!!!!
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596941
so you went from 400 rwkw to 300 rwkw just by taking advice from those in the know.... wow some people do acctually listen!
as for holding you own around the track, 400 rwkw doesnt mean you'll acctually do this... you'd more likely be whipped by a car with 250-300 rwkw and a responsive set up and able to put the power down better.
more power doesnt always = faster....
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596964
Thanks guys for all your help - im going with the GT-SS kit poss from nengun. Does anyone know if i'll be hit with any import tax's or anything? I have done some research and so far its been a mixed bag of answers.
Doug for a road/street car GT-SS's would be my pick.
https://www.sau.com.au/forums/topic/202672-want-400kw-atw/#findComment-3596989
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
