There is nothing wrong with 400rwkw....well unless you want more :D
Why not try the T517Z? I had them on my old setup and was able to put out 422rwkw on Willallracing dyno. The setup was a fun and reliable package for drag/circuit for 2 years aldready.
I upgraded the engine and maxed out these turbo with my current setup. I am looking at getting the T618Z's. I will use the T517Z for one more track day and will more than likely replace them with their larger bros. Does anyone have a pair of T618Z that they want to swap for a pair of T517Z? GTR747, if you are keen on these turbo or my complete old setup let me know. I changed the engine because the cam seals were old and a bit leaky but other than that the engine was still strong ;) I still have the power fc map for this setup. All you need to do is recondition the head, replace the rings, get a pair of manifold and you will have a reliable setup. My car and the spare RB26 are in SA atm too ;)
BTW sorry to go off topic but just want to help ;)
Edited by 9krpm
Thanks guys for all your help - im going with the GT-SS kit poss from nengun. Does anyone know if i'll be hit with any import tax's or anything? I have done some research and so far its been a mixed bag of answers.
anything over $1000 will attract duty.
Customs aren't silly.
They know all the people sending stuff in from JPN, so you'll be lucky if you get around it for turbos
come on, dont let them change your goal
you've gone down from 400 to 300 :D
go HKS 2530's, has both response and top end power
there's always room to improve your kw down the track, whereas with GT-SS, you won't improve much more than 330rwkw
what he said...2530's need 2bar of boost to do 400AWKW so its really stretching them too. GT-RS turbo's are the king of bolt on turbo's...currently powering the fastest bolt on turbo GTR on the planet.
save yourself some headaches, heartache's and lots of time and stress. Sell all the gear you have and buy our car...simple 500kw all day every day at a lowly 25psi.
Funny Funny lol but its true fastest bolt GTR on the planet
Im not saying i'll get around it, just how much duty it will attract roughly :rolleyes:
There is nothing wrong with 400rwkw....well unless you want more :rolleyes:
I upgraded the engine and maxed out these turbo with my current setup. I am looking at getting the T618Z's. I will use the T517Z for one more track day and will more than likely replace them with their larger bros. Does anyone have a pair of T618Z that they want to swap for a pair of T517Z? GTR747, if you are keen on these turbo or my complete old setup let me know. I changed the engine because the cam seals were old and a bit leaky but other than that the engine was still strong ;) I still have the power fc map for this setup. All you need to do is recondition the head, replace the rings, get a pair of manifold and you will have a reliable setup. My car and the spare RB26 are in SA atm too :)
wow I never knew the 517z were capable of that much power...at what boost ? I always thought for those sort of numbers a 518Z was required....awesome result
hmmmmmmmmmm....a gift ay, :(
I didn't think they T517Z's were capable of that much power either !!!! :P
if your interested in buying from japan can i suggest emailing Streeter (he normally trades on ns.com) far far more reliable and cheaper then neugun. his email address is [email protected]
awesome reputation also so have no fear ordering from him
+1
best and cheapest way to gets stuff from from yahoo auctions, with the least hassles, even if you speak japanese :)
Remember whith trust t517z you need trust dumps becuase the internal wastegate is on the opposite side to garret trubo, so you need dump pipes to suit..
9krpm, your turbo's are still T517z just with a 10cm housing, they also come in a 8cm housing, much like you can get say a garrett 3071r in a .64, .81, .96 housings ect
Edited by Dynamix
wow I am really impressed by these T517Z's....Anybody else got any experience with them ? or maybe with the 518Z ? They seem to be a fair bit cheaper than equivalent HKS and yet perform every bit as good and maybe better..But last I heard was they dont come with water cooling...is this correct ? As a circuit/Street car oil coolers would then be even more critical...I am assuming
I would love to hear more about the T518Z too. I have a Greddy oil cooler kit and the oil temp has been fine at QR raceway. I only overheated once at Mallala but that was possibly from air in my coolant system.
Thanks for the info Daynamix;) I thought they are T5178Z all along :)
How is this differ from a T618Z and what would I expect with the larger turbo?
BTW the previous power was achieved with 18psi.
Some people call them either T5178z ot a T51710z, the last numbers which are 8 and 10 on both the names i mentioned refer to what size housing they are, eg T5178z would have the 8cm housing, and 10 would be the 10cm housing.. The differences between the T517z and the T618z would be like the difference between HKS GT-SS and GT-RS turbos.. T618z would be to big for the rb26, as they're the biggest low mounts trust make and would be suitable for a 2.8 stroker, just keep you current one's, they're a great bit of gear, i'm tossing up weather to run them on my next gt-r..
URAS will be able to give you some more info on these turbo's as he's built an rb26 s13 with these turbo's for driftcat..
Cheers.
Thanks Dyn. I bought a slightly stroked engine from Willallracing and have maxed out the T517Z. They currently have awesome midrange but are choking my top end. I can't produce any more top end power with them compare to the 2.6L. My tuner is tweaking it atm and I will see how it perform at the track.....but I think I will go bigger eventually :)
  • 6 months later...
Customs are silly and there is no duty on turbo's GST yes Duty no definitely not.
They tried to slug me duty and as I know people in the import export trade i asked they they knew straight away
Get a good customs broker and they will tell you the same
cant get around GST though
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
