hi,
i am building a headache of a car which is going along nicely and about 70% complete...
i have a s15 and ditched pretty much all the running gear and gone for a mix of parts from all different nissan cars.
as the majority of you know, there will now be a weight difference and possibly a balance difference in regards to the cars handling...
i have no idea what to do in regards to where would i start to modify the suspension.
there is a shit load more weight over the front and you could say the same about the ass end but what would be my best options about getting custom coilovers for my car...
should i weigh the old items i took out and compare the weights with the items going in and record them????
would this help in selecting the best possible setup for me???
Im sure balance would be affected in this case so what approaches do i have in regards to this???
the car will be used primarily for drag which is no issue as i will use a standard height strut combined with a 90/10 shock for drag racing, im after a nice track setup as i will be hopefully doing a fair bit of track work in it, im not to fussed about stiffness, i can handle the hardness of coil overs on our shitty roads..
all help appreciated..
cheers
denis
Edited by den001
piece of piss although dont expect it to ever handle as good as it did with the SR :)
we run a similar setup but now use R34 GTR rear as the geometry is far superior to the r32 GTR
hi,
cheers
denis
Done the suspension on a few RB20/25/26/30 into S13/14/15's, nothing too drastic required. Think about the total weight of the car and then net what % you have added. It is usually very small, around 12% in fact. So going stupid in spring, bar and shock rates is simply not necessary.
This is the bit that concerns me;
If the "coil overs" are so harsh that you feel very uncomfortable on a normal road, then the car is 99% guarateed to handle badly. Despite what urban myth would have you believe, you can have reasonable ride comfort, good lap times and fast 60 footers all at the same time.
Cheers
Gary
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
