march this year i have been told... waiting to see the fruits of cancelling the 34R build up....
I can wait till the end of the year for it to be on the road, just want to see the thing and say its MINE!
Are you talking an R35? How have you swung that? Are you buying a test car?
  • Replies 66
nope no race rally. there are other ways.... wait to see it happen first.
Think of the shell like this, its caged. How much do you think it costs for a decent cage??? answer=alot of coin
How much do you think it costs to seam weld throughout the shell even under the shell???? answer=alot of coin
How much do you think it would cost to acid dip??? answer=you cant....
Its worth the dollars for someone who wants an absolute animal set up, bugger all weight, stiff and rigid...
Dux nuts paul by far.
yeah talking about the 35R, i didnt swing just fell in to place. no not a test car.
oh, personal import then.
good luck with it.
I think I will either wait for SEVS or NISSAN.
http://www.caradvice.com.au/9763/nissan-gt...perth/#commentshere is the coverage sorta.. god dam its so hot
I dunno why but for some reason it really irritates me when someone calls something mass produced "bespoke"
Looks like a fun toy.
  • 4 weeks later...
damn good thread guys then it stops. what was the verdict with bringing the car in? was it No, Personal import as in it was or it came in another way. Too true also Nissan should have grabbed one ASAP and had it doing the rounds. Hoping there will be one on show at the Melb Motor show starting this week....................
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
