Make:2007 Holden Astra
Model:SRi TURBO coupe
Milage:under 5000K's
Transmission:6 speed manual
Colour:Metallic Black
Complied?y
RWC supplied?n (not needed in S.A)
Currently registered?y 10 months left
Price:$30,000 o.n.o
Contact:0411392083 call for any more info
Comments / Modifications: Comes with all SRi options.inc tinted windows, climate, leather seats, has had first service, car is in NEW condition
Images:same as this, http://www.allcarwallpapers.com/wallpapers...-turbo-7923.jpg
Edited by shy_s6
https://www.sau.com.au/forums/topic/202732-07-astra-sri-turbo/
  • 1 month later...
