Item: Tamiya Petrol RC
Condition: Good condition recently fixed up.. although the servo that controls the accleleration needs replacing, currently the car runs at only one speed.
Price: $200
Comments: Comes with spare glow plugs, fuel, remote, two bodies (supra and ferrari) supra pretty banged up, spare fuel line, filter oil, battery etc...
https://www.sau.com.au/forums/topic/202752-tamiya-pertrol-rc/
