Had a couple quotes for an exhaust for my GTR 33.
Full exhaust, dump pipes, high flow cat etc etc
All around $2000+
That a bit steep????
Anyone recommend any where to go?
And also whats the best size exhaust to go for?? Performance wise?
Cheers
https://www.sau.com.au/forums/topic/202758-exhaust-places/
  • Replies 42
Exhaust Technology on goodwood road, near the underpass are great.
i have had some small fixes etc done by D&T in the city cos its close to my work, but if it goes on the books, and not a cash sale expect to part with a fair few $$
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598054
give them a call and find out prices i guess.
when i was calling up trying to find prices for my extractors, Exhaust Tech were the only ones with the best price, best service and the ones that didnt want my car for nearly 2 weeks :(
Exhaust Tech only needed her for a day and a half and the extractors cost 680 made and fitted, while every else wanted 1200+ plus.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598066
AAA Exhausts, system for GTS-T was $1300 cash so id imagine GTR to be only few hundred extra. Top notch work & they generally use the magnaflow stuff which gives a nice deep sound without making too much noise.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598130
The bigger the exhaust the more noise you will make!!!!
Three inch is big enough, but you can run up to 4 inch piping if you want.
Please remember that you have two dumps and this is where alot of the cost is as well as the type of cat used and the rear box. Jun BL boxes sold by ET sound insane and i havent managed to find something that sounds better as yet.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598205
Cory from Fisher Performance for a full custom setup with your choice of mild or s/steel.
He's got some great ideas for what works with a twin turbo setup at very good prices.
My 34 GTR is booked in next Wed.......tell Cory that Pete the Investigator sent you and he'll look after you.
https://www.sau.com.au/forums/topic/202758-exhaust-places/#findComment-3598472
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
