Wreaked - R33 Gts (1995 S1) $1500
I have an R33 GTS that has been written off due to being t-boned. Although the car is not worth getting fixed the damage is not actually that extreme and only the rear quarter panel and suspension has been taken out. All the rims are still okay and everything else inside and out are in good condition.
The car has done 128000ks and the engine is in perfect working order, as is the gearbox. All gears work perfectly. This is an ideal buy for someone needing parts!!! Comes with everything except for the dash. All I want it $2000, the gearbox and engine are worth well over that alone.
Anyway looking at $2000 ono for the entire car as is. The deal is you have to come and pick the car up which will require you to tow it away. I do not have the time to remove the engine or gearbox so I am just selling the entire car for $2500 ono!
http://www.skylinesaustralia.com/forums/in...t&id=130300
http://www.skylinesaustralia.com/forums/in...t&id=130302
http://www.skylinesaustralia.com/forums/in...t&id=130303
Edited by MSPEC
  • 3 weeks later...
 Share
