Hey guys, im doing my rb26 timing belt for the first time and have few questions.
Ive removed the 30mm crank pulley bolt, on the crank pulley itself i see alot of notches(one is orange), i was told the orange one is when your crank is TDC(when lined up with the crank pulley bottom cover timing mark)?..... Anyway, ive been reading a couple of good guides...what i want to know is once i remove the bottom cover (the crank pulley cover), will there be a notch i need to line up?if yes, whats the purpose of the nothes on the crank pulley itself (if the main one is behind the cover), is it just to make 100% sure that when the crank pulley is back on, that your crank is align 100%?
Im a bit confused on this one thats all.
Edited by r33turb
mate, I try not to be a dick about this, but did you even look for this info? we did it yesterday in this very same forum
http://www.skylinesaustralia.com/forums/Qu...me-t202329.html
Thanks, so ill have to remove the balancer, and the cover to get access to the timing gear? So would it be safe to say i can setup all the timing with the cover off, and once timing is lined up with the bottom, and 2 cam gears, i can place cover back on and rotate the balancer to get the ignition timing correct(as by this stage my main timing will be spot on),.....am i on the right track here?
thanks!, im going to be doing tommorow
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
