spinning is just cause the guy is treating the dyno like its a race track, kinda silly really
Not as silly as you think.
The car is strapped in quite nicely and he was launching it because they were doing 1/4 mile simulations with the guys in the background going " 10.68, woohoo!" obviously referring to a 10.6 down the strip.
i think thats a great idea for gaging a cars potential 1/4 m times. :(
whats silly about it? I just saw a vid of a 2500 HP supra on a dyno. I think if a dyno of ANY make can handle 2500 ponies, surely, it can handle a standing launch from a car only making 600hp..
#braces for inevitable admin backlashing#
Edited by m3gtr
https://www.sau.com.au/forums/topic/202846-r34-gtr-on-dyno/#findComment-3602490
I think it's clever to bring accelleration into a tune. Certainly analysing the 'time' delta of mods is just as meaningful as horsepower. It picks up non-horsepower changes as a result of things like changes in rotational inertia and throttle response mods that are invisable only looking at horsepower. Enrichment fuel mixtures can play a part in response on and off the throttle pumping and can add precious milliseconds.
The time measurements also remove the 'happy dyno' to some degree, as we can measure the time 'in gear' to go from one speed/rpm to another. Things like gearing and rim/tyre diameter can then be given a chance to factor into the equation.
Certainly doesn't fully replicate on track logging of conditions but, in terms of tune analysis it's the next best thing.
Edited by rev210
https://www.sau.com.au/forums/topic/202846-r34-gtr-on-dyno/#findComment-3605178
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
