ok, i've done the research and tried what people have recommended to me
the car (1996 R33 GTS SII) has been serviced every 5000km since i've owned it except for missing an oil change
NOW my question is, over the last two weeks i've put in a new set of NGK iridium plugs, i've replaced the air filter and fuel filter, and i've run a full tank of BP ultimate with injector cleaner... WHY IN GOD'S NAME IS IT PINGING LIKE MY DAD'S 1982 FORD LASER?
is there something i've missed? does it just need a tune by someone who knows their shit?
a bit of information on how i drive it in case it helps...
it's my daily, but i give it hell every now and then, also, the mrs drives it and changes gears at around 2400rpm but she's learning slowly lol
it pings under load in the lower rev range (anywhere under about 3500rpm) which sucks ass working on bell st, preston.
it'll still hit 100km/h in 2nd gear, but it takes around 8 seconds to do it.
this is not right... does anyone have any ideas about what's wrong with my baby?
https://www.sau.com.au/forums/topic/202850-pinging/
maybe get the timing put back, nearly 99% of the time my car has pinged, it cause of the timing............other than that maybe use octane booster ( a good quality one - such as Justice Brothers Octane Bootser)
https://www.sau.com.au/forums/topic/202850-pinging/#findComment-3599684
the timing was the only other thing i could think of, but why would it suddenly start up on a car that has been properly maintained and serviced?
beyond that, i run it on 98 octane fuel every time i fill up, 95 if i'm really in a pinch, but that should be easily enough to not be the cause of my problem
it's due for a service in the next week or two anyway so it's getting one whether i like it or not and if it doesn't clear itself up within the next few days (new fuel filter and all) hopefully the guys at the shop will be able to fix her up for me. i hate to hear an RB sounding like that, especially my own
https://www.sau.com.au/forums/topic/202850-pinging/#findComment-3599849
any recommendations on decent mechanics in eastern melb?
i bought the car at kamikaze motors, and have been getting it serviced at their affiliate workshop down the road, sumo performance or something like that, but they seem a little cheap, and i've never noticed much of a difference between taking the car in and getting it back.
beyond that, i'm beginning to think the problem is a little more serious. today, while sitting in traffic, it stalled for no reason. not in gear, not moving, just dropped revs a little when the climate control kicked in, then choked and died. it took a couple of tries to get it to start again, and now i have less power than before i replaced the plugs and fuel filter, it chokes unless i'm flooring it, and it's louder. i have this horrible feeling something has gone pop. please dear god tell me i haven't blown the head
https://www.sau.com.au/forums/topic/202850-pinging/#findComment-3601611
lol yeah the fuel filter and the air filter are fitted properly, they have this lovely little stamp on them that says "in" and "out". i'm thinking it would be pretty hard to f**k that up. i got the car serviced over the weekend at sumo performance and they replaced my $130 iridium plugs with a set of basic NGK plugs worth about $50 stating "oh we've found that the shit plugs are better than the good ones". they were nice enough not to charge me for them because, surprise surprise, they didn't fix the problem AND THEY COULDN'T BE ARSED TAKING THEM OUT AGAIN, but still.
anyway, the misfire is gone after a big ass service, but it still idles badly from starting up until i've driven for 5-10 mins. this doesn't really phase me as much but it's still a bit irritating. also, i have less power now. it's equal through the whole rev range (about 2k all the way to 8) could this be because of the shit plugs?
https://www.sau.com.au/forums/topic/202850-pinging/#findComment-3621031
    • What a wonderful journey to read. Loved the photography. Literally found this an hour ago and couldn't stop reading, plus checking out a couple of the links. Was interesting as you had a few mods very similar to my sons Gtt, including the sheetmetal homemade V-Spec II rear diffuser, can't be too many of them around the world. Only to find it sold about three weeks ago. Well at least I won't have to keep re-visiting for updates. Anyway, well done on not just the car but the well written story and descriptions, and of course the pics. Good luck on your next one. Rob
    • Forgot to update. I ended up removing it and found out that it's dead. The car seems to run better than it did, although I haven't driven it hard yet. Literally just a flow restriction.
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
