I like how my car runs after the new tune (but i will get used to/over it), it has a r33 turbo, FMIC, 3in exhaust and runs an Apexi SAFC. 174.5kw at wheels
I wanna know if i can bolt a bigger turbo onto it and still use the SAFC or do i have to go onto a stand-alone unit? Im not looking for massive power, just a good turbo upgrade.
Any help is appreciated.
Edited by dave_1
the car would perform significantly better with a stand alone ecu
it will work with an safc, but a true stand alone when setup properly will perform better
this is typical across response, performance, power, torque, fuel economy and drivability
I've always been a skeptic about piggyback ecu's or signal benders ... I reckon its a fine line between happiness and disaster with them.
They are really only good for minor modifications and if you are considering going and spending the money on a bigger turbo, injectors, etc etc you might aswell save up and get a whole new ecu to go along with it.
This might be an expensive option at least this way your going to have the least headaches overall.
Do it once, do it right <--- IMO :cheers:
I've been looking into this new to Oz ecu the Tomeii Reytec ... which is basically the standard computer modifeid by Tomeii so that it becomes a completely programmable unit.
From what I read going this route you can keep the factory computers fail-safe mechanisms and are able to tune for almost endless modifications. It appears to have a data logging function also!
Best ecu at the mo IMO :)
Edited by BLK33T
if you have a bigger turbo,
MOST definately get a decent aftermarket ECU. Will perform much better. By 'perform' i dont just mean the power you can get out of it ofcourse, it will keep your engine safe and at a decent tune.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
