I noticed in another topic someone was saying their vacuum is dropping to -60mmhg on idle. According to my boost guage mine is sitting at -40Cm/hg(-4.5 to -5.5 on standard guage) or around abouts and just wondering if I might have a leak somewhere? Engine runs fine and boosts ok.
Does anyone know what it should be sitting at with no accelerator input?
Any easy ways of finding vacuum leaks?
Cheers,
Adrian
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/202858-normal-vacuum-on-idle/
if its leaking it would expect it to show sea level pressure so -0 or thereabouts
like mine was when it was leaking it was showing -60mmhg, which is almost absolute pressure (ie: its leaking to the atmosphere)
so it essentially shows sea level pressure instead of vacuum - under vacuum it should be a fair whack off 0
my guage is showin -0 on idle...i bought the car as it is and ive noticed that the guy who owned it before me has installed a t-piece inbetween the vaccum hose between the wastegate accutator and what ever that goes to...is this why it would be showin -0 because my car runs fine????
I just realised the previous user has put in T-piece that runs to the standard guage and then also runs through to the dash(probably to the other guage). None of these connections are have fastners on them so I might buy some and see if that helps. It seems a very slight is coming from where it connects to the plenum.
I have two skylines in my driveway and one sit on -20inhg and the other at -16-18ish inhg, the second one has a front mount! would that have any effect on the vac? I have checked it for leaks like 20 times. and came up with nothing, I hope that it does'nt mean the engine has less compression?
would it?
Sweet it was just my gauge!!!!!
Edited by RPR33
  • 3 weeks later...
ive got a related question.
at idle (warm) my boost gauge shows the normal ~20 vac (psi gauge). on cold start when rpm is around 1100 it used to show less vac, like 15 or something, till the revs dropped, but now it sits on 20vac at cold start. not sure which of these is normal.
the factory gauge shows similar figures.
if i rev it at cold start, the gauge moves up accordingly. all other readings while warm etc seem fine.
cold start and idle are spot on. no idle hunting, etc.
which one of these readings do you guys get at cold start? 20 vac, as when warm? or higher. eg 15 vac?
Edited by Munkyb0y
ok to the person who says his car shows 0 cept when off boost and its t peiced of the actuator line, this is normal, as your only showing positive pressure on that line as it comes off the turbo hosing itself, t it off a line from the manifold instead, eg blow off valve line and it will show correctly
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
