Hi fellas,
Please help me out - I am getting my new 18" rims put on this Saturday (they didn't come with any wheel nuts) and will have to obviously remove my current wheels from my car. Only issue is, the current set of wheels have lug nuts on them (aka lock nuts) - now, the thing is I have lost the key to these.
So the question is; 1) will I be able to get them removed without damaging them so they can be reused? 2) if they're going to get damaged and won't be reusable - do you think the TyrePower place can sell me some cheap ones?
If anyone is from the Western suburbs of VIC that has a set (4x5=20) lying around, please let me know.
Thanks,
SM
if you take it to a tyre place they will just smash them off, and hopefully wont damage the rims if they dont have the key. Its nothing difficult.
If you want to do it you self, go down to supercheap or something along those lines and get a cheap socket that is 1 or 2mm smaller than the locknut (its going to be rooted afterwards). Then with a hammer smash it on over the locknut then with a rachet undo it, done. This will destroy the locknut, and if you dont feel confident, dont do it cause you will do more damage than good.
Edited by R34GTFOUR
Thanks fellas - thanks R34GTFOUR - so it's not the end of the world. So in other words, I'll definitely should get a new set of lock nuts then? Like some others have said, I should get a new one in case I get a flat and can't remove the locknut.
Well, at least I know it should be ok for now though. does anyone know how much a set of lock nuts will cost?
Thanks all for your help... i was so worried...
i wouldnt expect anymore than 30-40bucks for a set of just locknuts
Thanks mate... great news... I'll might as well get new nuts then... cheers.
You've been a great help - much appreciated.,
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
