R33 windscreen grill great condition $75 Delivered
R33 GTST complete factory airbox setup with snorkel $100 + Delivery
R33 GTST aircon compressor great condition $100 + Delivery
R33 GTST passenger side tail light complete white $75 + Delivery
R33 GTST inner door trims perfect condition $75 + Delivery
R33 GTST center console great condition $75 + Delivery
R33 GTST rear view mirror $15 + Delivery
http://img250.imageshack.us/img250/4595/image131kq1.jpg
R33 GTST coil pack brackets RB20-25-26 $15 + Delivery
Trust full turbo timer (missing small plastic cover over screen $40+ Delivery
90 Degree stainless bend for high mount turbo with silicon joiners $45 + Delivery
R33 GTST Series 2 power antenna motor $45 + Delivery
Adjustable guaged fuel regulator with universal adapter $45 + Delivery
Bilstein Suspension for R33 GTST with King low springs set in great condition sits the car about an inch and a half lower then standard and stiffens the ride nicely also $450 Delivered
__________________________________________________
Account Details:
Account Name : SLIDING PERFORMANCE
Account number : 034169026
BSB Number : 484799
Suncorp Metway
Please use your SAU user name as the transaction reference and provide your full name and delivery address.
If you do not list your user name this will extend processing time.
PayPal payments are accepted though must include a 2.6% surcharge to cover fee's on top of the items total : [email protected]
This has a 4 bolt flange and comes with the flange plate, the one on your manifold now can be cut off and the new one welded on :P
Didn't really want to.
If it is still here in a week $30 Delivered :D
no probs mate just remind me and ill have to get ur details off you vice versa
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
