the pinout on the auto NEo NA R34 (converted to turbo by bolt-ons) was nearly spot on but all the turbo ancillaries are not in the loom. i would personally swap ecu looms or just convert the NA to turbo.... the one we did used HKS gtrs and made 240rwkw on crazy low boost.
Trent, what do you mean by "all the turbo ancillaries are not in the loom" ? Can you pls specify what are they ?
My friend plans to use stock neo rb25de loom, neorb25de ecu, emanage blue to run the neo rb25det. I guess it will work, and all the issues could be cured with some time spent tweaking emanage.
  • 2 years later...
  • 1 year later...
A bit of an old thread but I've just swapped a de neo with a det neo. Auto box swapping ecus.
Retained wiring loom on the de neo. Retained throttle body from de neo and extended using silicon hose.
Tuned with emb and e01 running both map pressure sensor and afm.
Issues:
tiptronic gear numbering doesn't show.
Sometimes stalls and recovers on cold start and under load such as reverse full lock steering and or headlights on idle will drop to stall or near stall.
Air con on in start stop conditions will cause motor to almost stall when stopping. Can only have it on while cruising.
Mechanic has aac unplugged as it jumps to 2000rpm idle.
He reckons that it needs a constant voltage and it's providing the aac with varying voltage?
Any thoughts?
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
