Went to Autobarn today again because i didn't manage to remote start when the engine is cold. The whole idea of remote start is to warm up the engine. But autobarn can't fix it. So it's a bit useless for me to get remote start oledi. Spent so much for nothing......
At the same time, i also bought a boost controller and a blow-off valve. Anyway is blow off valve illegal? i think i prefer the factory made valve than the one i bought in autobarn. And there tune my boost to 1 bar.. will that cause any damage to my engine? IT's really a fast car now... Yippy~~~
Unless you have an aftermarket Turbo + FMIC i'd be turning that down. From my memory 1 bar = ~14.5psi which for a stock R33 Turbo is way too high. Try setting it to about 10psi and 12psi if u have a cooler and not too hot a day.
BOV is illegal in Vic if u do not plumb it back.
U should be able to get the remote start to work even on a cold day. Take it to another alarm installer.
For me, turbo timer setting at 1 min all the time and set the rest of the time to auto depending on how much u r boosting it
As Benm says, run it on 10psi for stock turb and it should be sweet.
Good luck with your skyline :)
  • 1 year later...
Think about it this way. If anyone really wants your car, they'll tow it. But get a reality check. Your car is not a porsche, it's just a 20000 skyline. Most likely, they wouldn't bother with a towtruck.
I do a fair bit of work installing alarms, and i'll tell you that no matter how you install the alarm, it's still fairly easy to remove the alarm. Think about it this way, how do you install it? you cut wires, and join in the alarm. What will stop someone from removing the alarm unit, and rejoining the original wires (join wires of the same colour) ? Shouldn't take long at all. 4-5 hours to install a good alarm, 10 minutes to "uninstall" it. Alarms are more of a deterent for kids, or inexperienced people who think "oh, i'll just break into that and hotwire it and get a skyline!"
True, i got an alarm fitted in my car the other day (wont go into details) and while it's not a bad system i didn't go for the best on the market, there just seemed no need.
There are some simple ideas that might make your car less attractive for thieves, such as garaging it at home, and parking next to more expensive looking cars in shopping centres :P lol
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
