  • Replies 172
evil weevil - is this the pic that you wanted?? :rolleyes:
the car might make 15 - 20
maybe 14....
but the top 10 no way
that car??.....top 5 for sure man......fulli hektiknez just overwhelms all other competitors.
ahahah nah man, i meant the gtr......
but sure, for the hektik bros out there teh vl might even hit the top 3
Well into the top 10, being 4wd and basically purpose built it will flog em on the track....also the straight they use isn't huge so terminal speed shouldnt come into it. Its a stretch but it may well top the table... as stated purpose built 4wd it will be right at home.
lol
We'll see....... >_< at the peeps talking about "keeping it in it's usable power band" ect.. you'd think it's a big single turbo r32 we were discussing.. Intead of a 3.8 v6 twin tubo with an almost linear power delivery, the cars not a pig on the track regardless of track size as it's testing has already shown. Could be something to do with the design brief to build a car with "supercar stats" instead of a GT production racer. The r35 is a few generations more advanced than all previous gtr's and is also in a different class.
Lol you must old calling me son...Lad >_<
Nah I doubt it... it was a throw line away as if to say I wouldn't be suprised where it came.
The a10 does have it on power to weight and although it's distibution of weight is near perfect....but it's still a 460kw RWD which makes it a bit of a handful on tightish tracks without a huge straight. The stig will be able to wring the life out of the GTR without much care, the car won't dissappear in a cloud of smoke. It'll be interesting to see.
Edited by madbung
The response of the new R35 GTR on a very tight 'driver training' track was insane, looked absolutely balanced. I think you can forget it's going to have any problems.I talked to the guy pedaling it and he said it felt incredible and had balance unlike any car he had ever driven, including much smaller worked over evo's, the car is just planted to the road.
I'm thinking between the Z06 and the Ascari.
If anything, the GTR MAY come close to matching the time of the LP640; but i still find it difficult to see how it will beat the time of anything faster than that. Those cars might be RWD, but they weren't exactly struggling for traction when driven by the Stig (if i remember correctly).
being such a small track i dont think that outright power and top speed r going to come into it, i dont think it will make the top 10 maybe top 15 but there are some awesome cars on that list like ther koeniggseg (or whatever) which r tiny and seriously fly.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
