Hi all. I just have a quick question that maybe someone will know whats going on.
I have installed two amps into my car, one for the speakers inside and one for the sub in the boot. I have wired the triggers (on signal) on both amps, up to the trigger on the head unit. This should then allow both amps to come on once the stereo is fired up.
If i turn the key ignition to the assessories position i can turn the stereo on and both amps come on as they should. Stereo works fine in this situation.
Okay, well if i go to now start my car, which causes the stereo to flick off and back on, one of my amps goes into Protection mode and wont work. Both amps are different brands. With the engine running i can then turn the head unit off, then straight back on again. After i do this, the amp that was in protection mode, starts to funciton correctly.
This happens everytime i start my car with the stereo already on before i turn the key to the start position. If i turn the head unit off then shut off the car and start it again. Then turn the head unit on, both amps work fine.
It is a bit annoying having to turn the head unit off and on all the time. I was thinking maybe a time delay circuit or something might fix the problem. I am thinking that when i start the car, there must be a bit of a spike in the current going thru the trigger wire to the amps. The cheaper crapper amp seems to not like this.
Can anyone suggest maybe what i should look at. I thought perhaps a Capacitor included in teh circuit there somewhere might take that edge off the power spike fixing the prob?
https://www.sau.com.au/forums/topic/203055-amp-problem/
you need a relay on the trigger lead.
find a 5 pin relay (jaycar DSE etc.) and wire in this fashion
85 - gnd
86 - radio trigger in
87 - +12 battery (from amp supply) via 5A fuse
30 - amplifers.
give that a burl.
https://www.sau.com.au/forums/topic/203055-amp-problem/#findComment-3605872
Sweet thanks mate. Yeah i will have to give this a go. But one of my amps is f!*ked now so i will have to buy a new one. I will do this if i have probs with the new amp.
u should check ur wiring becasue it sound like ur earth wire is lose if it still doing it try runing one earth wire for each amp and one power wire 4 each ampbut use 4g wiring 4 earth and power becuase one amp is taking to much power
https://www.sau.com.au/forums/topic/203055-amp-problem/#findComment-3611185
This is a very odd problem. Sounds like your HU could be faulty and it's not sending enough current to the amp in order to switch on the power supply. A feature of MOSFET amps is that if they dectect discrepancies in the switching line they shut off to prevent shorting exc.
Try hooking the remote wire up to your accessory line instead. This will solve the problem and will eliminate any delay from the HU signal. (if there is any)
The relay will also work, but would take much more effort to implement than this. You will have to attach the rem wire, power wire and an earth wire/lead to the relay. So you're going to have to hitch power from wires all over the place and run them to the relay. Can be a messy procedure.
I'd reccomend just hooking them up to your acc line. That way your switching power supply won't have any chance of being starved and it won't activate your protection mode.
Try doing this, if it still doesn't work speak to me again as you may have overloaded your ACC line!
Hope that helps!
Edited by Domenico
https://www.sau.com.au/forums/topic/203055-amp-problem/#findComment-3626437
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
